J
jonnycraig
Hi, heres what VAGCOM brought up.
Car seems turboless at the minute, still gets up to motorway speeds but takes a while!
IMHO the Catalytic convertor is knackered as blocking the exhause pipe.
5 Faults Found:
00575 - Intake Manifold Pressure - If the Cat was broken up would this do it? (Can I deCat it and still pass MOT?)
17-10 - Control Difference - Intermittent
00741 - Brake Pedal Monitoring -This one was existing from the last time I scanned, need to replace brake switch
27-10 - Implausible Signal - Intermittent
65535 - Internal Control Module Memory Error - ????
00-00 - -
17978 - Engine Start Blocked by Immobilizer -Immob light was flashing during tests, key out and in sorts this most times.
P1570 - 35-00 - -
00553 - Mass Air Flow Sensor (G70) - I did this, unplugging / reseating the MAF
31-10 - Open or Short to Ground - Intermittent
Im afraid to clear the codes and see what ones stay behind as was told that cause the car is in limp mode now it may not start after clearing as it presumes its in the garage lol?
Jonny
5 Faults Found:
00-00 - -
P1570 - 35-00 - -
Jonny
