    Jun 2012
    Essex
    59
    can you re code a replacement ABS module with the shareware version of VCDS lite?
    Hi, Quick question - can you re code a replacement ABS module with the shareware version of VCDS lite?
    i have a replacement module with the correct part number, i'm assuming i will have to code the replacement to the car, is that correct?
    the car is a 1998 Audi A4 Avant 1.8 petrol
    27,089
    It would help if you advise of the car, year etc
    Jun 2012
    Essex
    59
    a good point well made . . . .
    27,089
    98 B5 is Kline, which vcds lite allows functionality, check the compatibility table here:
    Ross-Tech: VCDS: Function Table
    Jun 2012
    Essex
    59
    that`s great - thanks very much
  1. will a replacement ABS module work?
    By deejames in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd July 2013, 22:38
  2. Can you still buy brand new dash displays for the S3
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2010, 09:08
  3. ABS module on the abs pump
    By sun and kath in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2010, 20:56
  4. Can you help-vag fault codes?
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th December 2007, 06:16
  5. can you tell me how to fine the colour code
    By mb29163 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th May 2007, 13:52
