Chris NottEM Tuning
    Tricky1971's Avatar
    Apr 2013
    Chelmsford Essex
    11
    Rear door module problem regarding retrofitting illuminated door handles
    I have a Audi A4 b8 2010 sline avant vin no.WAUZZZ8K9AA133596 and have retro fitted illuminated door handles, warning and puddle lights in all 4 doors and recoded all in vcds. All the fronts doors work fine but the rear door only the handles don't light up on both sides. I was advised by t8ups that some of the modules of the rear maybe need changing and removing the door card I found my modules didn't have pin 3 which the rear door handles are wired to.
    So I checked on topic on audienthusiasts.com on installing ambient lighting controlled door pocket lighting which mentioned about some modules have shaded or half shaded blocks in the position they are in the car on top right corner of module.
    So I purchased 2 modules from eBay.de with the same part number but a different letter at the end and shading in the blocks as required, I installed them and recoded them but still no door handle lights plus I have now lost the puddle and warning lights in rear even tho I coded them in and have no fault codes. These modules have pin 3 required for the handle lights. Not sure what to do as Pns2007
    on this forum said its something to do with the letter at the end of the part number that denotes what the module can do?, and advised looking on Etka but I don't have this info. Can anyone help?
    Original module number 8k0959795C
    Replaced module number 8k0959795E
    pns2007's Avatar
    Nov 2008
    627
    Re Etka, you can view it online if you don't have the program. will need something like google translator but it works fine. I retro fitted the lights in my car a few years back. I will see if I can dig out any further info for you. VIN-online.ru (ETKA) - Audi A4/Avant
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    Tricky1971's Avatar
    Apr 2013
    Chelmsford Essex
    11
    Ok cool many thanks
    Rich
    pns2007's Avatar
    Nov 2008
    627
    Rich, I don't have the scans for my A4 anymore. If you check out my thread regarding the door warning lights there is a guy called Scottie who if asked may supply you with a vcds scan. Once you have a scan of a car with the light pack you will at least know one version of the door control module that will work. Ask in the A4 (B8) section for others to post their scans.
    Tricky1971's Avatar
    Apr 2013
    Chelmsford Essex
    11
    Ok thanks I will check it out and let you know. Thanks for help
  1. Rear door module issue when retrofitting illuminated door handles
    By Tricky1971 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 13th May 2013, 12:54
  2. A4 b8 rear door module problem with illuminated door handle retrofit
    By Tricky1971 in forum General Technical / How To
    Last Post: 13th May 2013, 12:51
  3. Rear Window,courtesy lights & door warning PROBLEM
    By quattro25years in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 7th May 2008, 16:36
  4. Rear Wiper & Passenger Door Mirror Problems
    By imported_vando in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 09:50
  5. Door Latch Problems!!!!
    By jondana in forum TT/TT-S/TT-RS Forum
    Last Post: 20th February 2004, 10:39
