Volks AutosAH Fabrications
    May 2013
    Lightbulb Enabling Touring mode in the Exterior lighting menu
    I have successfully enabled and disabled the touring mode with vcds to do the headlamp conversion. However by using the hidden menu I also found that the Exterior lighting menu can be changed. The current number is 5 and three items appear in my menu. If I increase the number do you think I will be able to enable the Touring mode menu to appear within my exterior lighting menu. I hope I make sense.
    27,029
    Without advising us of the car it doesn't help allot.
    May 2013
    My car is Audi Q7 3tdi sline with mmi 3g. 2010 model. I tried changing the number from 5 to 6 under exterior lighting - carmenuoperation in hidden menu. The whole "exterior lighting" menu disappeared. I was able to bring it back be changing the number to 5. So which number will enable the "touring mode" option?
    May 2013
    I am trying to enable this option so that I can use this feature before leaving the ferry or the tunnel between France and UK instead of using the laptop and VCDS every time. Please help. Anyone?
    I will have to power my laptop from the car while working with vcds. Is there a major risk of shorting the circuits if i do this?
    Jan 2012
    1,837
    If you to into your program directory there is a text file in the Debug folder where it shows you the changes made.
    In hind sight, don't fiddle with things if you don't know what you're doing.
    It only takes less than 2 minutes to change it with vcds.
  1. Where can i get the exterior B-Pillar chrome trim for an 02' S4?
    By matthew860 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th April 2007, 04:02
  2. can you get the led lights for the s3?
    By edward_harris in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2007, 10:29
  3. little red neons in the indoor light cluster
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th March 2007, 00:04
  4. Help with the boot light
    By natedog in forum RS6 Forum
    Last Post: 6th October 2006, 11:03
  5. RE: HOW2 RESIT THE INSPECTION LIGHT
    By lakhan in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2004, 16:11
