JMB RetrofitsVolks Autos
Results 1 to 15 of 15
Thread: How to use VCDS
    Apr 2013
    Kettering, Northamptonshire
    172
    How to use VCDS
    I've got a genuine ross tech vcds cable, ive got the software installed and i can do a basic scan but ive no idea how to use it all properly, i.e program things, how to get live readings etc, and guides anywhere so i can use the full potential of this software?
    May 2012
    RETFORD, NOTTS
    1,753
    Measuring blocks in each module to get live readings, coding and adaption to get into programming things. What car do you have and what did you have In mind?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    YouTube
    RossTech have a YouTube channel which is invaluable
    Apr 2013
    172
    Thanks, I need to code my rnse mk2 and I'll be doing cruise soon and maybe xenons, but when I go to code it says error 13 or something, are the certain things you need to do to code? Also want to get some readings to check wether everything on my car is running right I.e timing, injectors, maf etc, are there any figures that are correct to compare them to? I have a 2004 a3 2.0 tdi manual and a 2005 a3 2.0 tdi DSG
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    322
    always wise to have ignition on and all the doors unlocked as some modules cannot be read otherwise
    +incoming MY15 S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    Apr 2013
    172
    How do i code my rnse mk2? When i try it says error 13
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    322
    Quote Originally Posted by s3reptdi View Post
    well you say your cable is genuine, so why not contact rosstech for their advise about the error code?
    Apr 2013
    172
    Because im sure plenty of people have coded an rnse on here that could tell me how to do it.
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    Post up a FULL scan of the car, maybe you will get some better advise then.
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
    Mar 2013
    Bolton
    9
    where did you get your cable from dude?
    Apr 2013
    172
    VCDS Version: Beta 12.10.5 (x64)
    Data version: 20130408
    Sunday,12,May,2013,17:14:21:38973
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P75A122792 Mileage: 162450km/100941miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 1010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 DT HW: 028 101 189 2
    Component: R4 2,0L EDC 0000AG 7000
    Revision: 12345678 Serial number: AUX7Z0E0FNS06O
    Coding: 0000078
    Shop #: WSC 06314 000 00000
    VCID: 78FF560F0B4B76DEB69
    2 Faults Found:
    19559 - Motor for Intake Manifold Flap (V157)
    P3103 - 000 - Malfunction - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 12.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.86 V
    Bin. Bits: 00000100
    Torque: 0.0 Nm
    Torque: 92.0 Nm
    18034 - Powertrain Data Bus
    P1626 - 000 - Missing Message from TCU - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 10000100
    Readiness: 0 2 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 041 A HW: 02E 927 770 AD
    Component: GSG DSG 041 0822
    Revision: 04004010 Serial number: 00000503290006
    Coding: 0000020
    VCID: 102F0EAF03FB4E9E1E9
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0023174
    Shop #: WSC 06435 000 00000
    VCID: 3A7B8C0775C7A4CE80D
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    008 - Implausible Signal - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
    Component: KlimavollautomatH18 0260
    Revision: 291325 Serial number: 8P0820043M
    VCID: 3663983741DF40AE645
    1 Fault Found:
    01592 - Air Quality Sensor (G238)
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:05:11
    Freeze Frame:
    Temperature: 19.5°C
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H34 0301
    Revision: 00H34000 Serial number: 00000001490531
    Coding: 01884F06A214100000000000000000000000FE0F5C
    Shop #: WSC 01236 785 00200
    VCID: 3D71871B64E993F6A5F
    Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 01236
    5 Faults Found:
    01495 - Bulb for High-Beams; Left (M30)
    010 - Open or Short to Plus
    00978 - Lamp for Low Beam; Left (M29)
    01499 - Bulb for High-Beams; Right (M32)
    010 - Open or Short to Plus - Intermittent
    02401 - Terminal 75x
    006 - Short to Plus - Intermittent
    01800 - Light Switch (E1)
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011603
    VCID: 4385F1E3020DE506D3B
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 B HW: 8P0 953 549 B
    Component: Lenksäulenmodul H21 0050
    Coding: 0014142
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: Lenkradmodul H06 0030
    3 Faults Found:
    00895 - Cruise Control Switch (E45)
    014 - Defective
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    01301 - Control Module for Voice Recognition (J507)
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
    Component: KOMBIINSTR. VDO H73 0300
    Revision: D04 Serial number: 2240ED04005987
    Coding: 0000413
    Shop #: WSC 00000 067 57207
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Coding: 3F0F0B4A070101
    Shop #: WSC 01140 210 66111
    VCID: 285F464F9B6B265EE69
    Subsystem 1 - Part No: 1K0 907 530 D
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D04 Serial number: AUX7Z0E0FNS06O
    Shop #: WSC 06402 145 00197
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 B HW: 8P0 035 193 B
    Component: RNS-E PU EU H06 0200
    Revision: 0000012S Serial number: AUZBZ7L6100134
    Coding: 0215751
    Shop #: WSC 00243 211 180152
    VCID: 2F6DAD53BE857166273
    5 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:08:24
    Freeze Frame:
    Mileage: 162450 km
    Count: 1105
    Clock: 17:08
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:08:21
    Freeze Frame:
    Mileage: 162450 km
    Count: 1105
    Clock: 17:08
    00857 - CD Changer Unit (R41)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:09:01
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:09:41
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:09:30
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000048
    1 Fault Found:
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    012 - Electrical Fault in Circuit
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 H
    Component: EPS_ZFLS Kl.8 1502
    Shop #: WSC 00000 000 00000
    VCID: 3169AB2BA8B16796317
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 008000186D288505489AC63000
    Shop #: WSC 00046 412 819200
    VCID: F9F9D30BB041EFD6497
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Subsystem 2 - Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    2 Faults Found:
    01403 - Glass-Break Sensors; Rear
    011 - Open Circuit
    01565 - Luggage Compartment Light (W3)
    007 - Short to Ground - Intermittent
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH25 0160
    Revision: 00003 Serial number: 10000001160628
    VCID: F0EFEE2FE33BAE9EFE9
    2 Faults Found:
    00422 - Rear Right DSP Midrange Speaker (R106)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 162194 km
    Time Indication: 0
    Date: 2013.05.06
    Time: 19:46:21
    Freeze Frame:
    Temperature: 24.0°C
    Raw, Form. N/A: 000 000 000
    00421 - Rear Left DSP Midrange Speaker (R105)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 162194 km
    Time Indication: 0
    Date: 2013.05.06
    Time: 19:46:21
    Freeze Frame:
    Temperature: 24.0°C
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 E
    Coding: 0000048
    VCID: 3E73801769EF88EEBC5
    1 Fault Found:
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0215751
    5 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:08:24
    Freeze Frame:
    Mileage: 162450 km
    Count: 1105
    Clock: 17:08
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:08:21
    Freeze Frame:
    Mileage: 162450 km
    Count: 1105
    Clock: 17:08
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:09:01
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:09:41
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 194
    Mileage: 162455 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 17:09:30
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D51B75BB489037615F
    27,126
    Apr 2013
    172
    Have you got my PM's NHN?
    27,126
    Nope.
    Apr 2013
    172
    Just sent you one, did you get it? Don't understand what im doing wrong!?
  1. Dension Ice>Link gateway 100, how to use ipod UI mode?
    By kohoutec in forum In-Car Entertainment
    Last Post: 23rd December 2007, 10:50
  2. Now this guy knows how to use Microsoft Paint...
    By concoursneil in forum General Chat
    Last Post: 6th December 2006, 00:12
  3. how to use the search function ?
    By firestorm in forum General Chat
    Last Post: 27th February 2006, 13:27
  4. RNS-E with Audi Bluetooth & how to use vioce dialling.
    By imported_G4JSG in forum In-Car Entertainment
    Last Post: 8th January 2006, 20:32
  5. How to use a Forum
    By docurley in forum General Chat
    Last Post: 1st February 2005, 23:35
