VCDS for Ipad
quattrov6tdi
cork ,ireland
Is it possible?
And is it dangerous to clear fault codes?
If they don't return when you you rescan,does it mean that they fixed themselves or were intermittent?
Sorry bit of a novice but have a touran now as well so I best learn
RT are bringing out a mobile version in the near future but for now it's not possible.
Reactions: quattrov6tdi
As Chris said, VCDS-Mobile is due out shortly (it is going to be dearer than the current HEX+CAN interface).
Save the scan then clear the fault codes, they will not ‘fix themselves’ but if the fault does not reappear (intermittent fault) then the DTC will stay cleared.
I cannot see why it would not work on an XP tablet with a USB port (I currently use a netbook)
