Help with Xenon Plus lights Tourist Mode 2012 A3 Sportback Black Edition 1.8 TFSI
amoxitine
NULL
Hi there,
I have purchased a VCDS cable from VAG Diagnostics (VAG Diagnostics Ltd - VCDS Vag-Com 908, 912, & 10.6 Cables) in order to switch my headlights into Tourist mode so that I can drive on the right when in France, but having problems trying to do this as when I select the control Module '55 Xenon Range', choose Adaption 10, then select the channel called 'Activate left/right hand drive switch-over' it only shows the stored value as 'Unknown' rather than inactive/active. The cable comes with v10.6.4 of VCDS but I cannot use any other version as it says if I do then it can damage the cable itself.
I did spot an old post in the A3/S3 forum (http://www.audi-sport.net/vb/a3-s3-...ve-switchover-2012-xenon-plus-headlights.html) and I think I may have the same set of headlight as the guy who opened this thread, as when I look in the log I took the Xenon controller number is the same. As a total newbie to all this I couldn't understand after reading that thread whether I was snookered or that there is a way to make the change to tourist mode, but not in the way you would normally do it (as I outlined in the paragraph above)
If anyone could give some advice to a total novice to all of this and let me know if I'm totally wasting my time with the cable and version of VCDS I have bought to use with my particular model of A3 I would be grateful.
Here is a copy of the log I took if this is of any use?...
Cheers,
Dave
Tuesday,23,April,2013,00:06:11:37412
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 61 62 72 77
VIN: WAUZZZ8P2DA021173 Mileage: 7660km/4759miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDA) Labels: None
Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0040
Revision: AAH18--- Serial number: AUX7Z0L6FN40C2
Coding: 0143000C18070060
Shop #: WSC 06314 000 00000
VCID: 418334A06119
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 13424012492400FBC80C02EB921C0081380800
VCID: 7CFD8554467B
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0180
Revision: 000922 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78F599447243
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
Component: BCM PQ35 M 110 0667
Revision: AJ110667
Coding: 4E000A2FA005F0C0207041E00000095C421E2BAA304DD928E4000E840041
VCID: 3F87325817ED
Part No SW: 8P2 955 119 F HW: 8P2 955 119 F
Component: Wischer AU350 H11 0050
Coding: 00DD13
Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 15: Airbags (J234) Labels: None
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003JU007VBT1
Coding: 30314238303830303037554A305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 52A10BECB47F
Driver's Airbag Crash Sensor:
Serial number: 3572DRB40000EB48AA77
Passenger Side Airbag Crash Sensor:
Serial number: 3582DRB40000EB488A32
Driver's Rear Airbag Crash Sensor:
Serial number: 35128RB400006BBA101F
Passenger's Rear Airbag Crash Sensor:
Serial number: 35228RB400006BB9F6A1
Driver's Front Airbag Crash Sensor:
Serial number: 35547RB400006C39E49.
Passenger's Front Airbag Crash Sensor:
Serial number: 35647RB400006C39E7D2
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0004012
VCID: 468927BC4837
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: None
Part No SW: 8P0 920 983 J HW: 8P0 920 983 J
Component: KOMBIINSTR. VDO H03 0360
Revision: D0H03004 Serial number: 2246L004000697
Coding: 0260428
Shop #: WSC 17328 000 1048576
VCID: 418334A06119
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
Component: J533 Gateway H43 1632
Revision: H43 Serial number: 260612F1000648
Coding: 352103
VCID: 408531A46A13
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03004 Serial number: AUX7Z0L6FN40C2
VCID: 418334A06119
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0000692
VCID: 49932C805929
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 232 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 37775A783FDD
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0000692
VCID: 4A91138C5C2F
Address 55: Xenon Range (J431) Labels: None
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0012
Serial number: 120619-0002-157
Coding: 1163951010000000
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 42813BAC641F
Address 56: Radio Labels: None
Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
Component: R Concert2+ H06 0293
Revision: 00H06000 Serial number: AUZ1Z3M3175407
Coding: 0710101
VCID: 72E1AB6C143F
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 J
Component: Batt.regelung H43 1632
Coding: F326085A
VCID: F1E324609139
Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 42813BAC641F
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000144
VCID: 438F3EA87B05
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005557024
Coding: 0001222
VCID: 356B507025D1
You have a cable running (old) hacked software, this is the reason you cannot update it, the hacked software pre dates your cars software, this is going to be your biggest stumbling block.
Personally I wouldn’t connect any hacked software into a £2K car… let alone a £20K+ one, however it is your car and your choice.
