I have 2000 s6 that keeps suffering rough idle. Could it be air leak as idle goes high or is it in fact O2 sensors?
Monday,15,April,2013,18:15:29:57722
VCDS Version: Release 11.11.5
Data version: 20121222
Address 01: Engine Labels: None
Control Module Part Number: 4D0 907 558
Component and/or Version: 4.2L V8/5V G 0002
Software Coding: 05752
Work Shop Code: WSC 02325
VCID: EADEE597969E13481F8
7 Faults Found:
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 35-00 - Incor. Correl.
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 35-10 - Malfunction in Circuit - Intermittent
16534 - Oxygen (Lambda) Sensor B2 S1
P0150 - 35-10 - Malfunction in Circuit - Intermittent
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 35-10 - Incor. Correlation - Intermittent
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 35-10 - System too Lean - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 35-10 - System too Lean - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
Readiness: 0000 0000
Address 01: Engine (4D0 907 558 )
18:16:41 Group 001
760 /min RPM
85.0°C Temperature
0.0 % Lambda
0.0 % Lambda
18:16:59 Group 002
760 /min RPM
15.0 % Load
3.40 ms Inj. On Time
5.44 g/s Mass Flow
7 Faults Found:
18:16:41 Group 001
760 /min RPM
85.0°C Temperature
0.0 % Lambda
0.0 % Lambda
18:16:59 Group 002
760 /min RPM
15.0 % Load
5.44 g/s Mass Flow
