JMB RetrofitsChris Nott
    I cant spell !
    Jun 2007
    North West
    434
    Adjust auto light sensitivity
    Hi does anyone know the settings (in Vagcom) to change the sensitivity of the auto lights ?
    Noticed mine where on this morning when I really dont think they where needed !
    Also how long does it take for them to adjust - ie get it out of garage and it seems to tune them on and then take an age for them to go off - is this time changeable as well ?
    Richard
    MY12 Black edition TT Roadster with a tractor engine !
    27,114
    You'd need to login to module 09, ten coding, drop down box to select rechentungsensor or the like, then go into coding for that module, which may have percentages you can set, its all dependent on the chassis & sensor fitted, have a looksy.
    I cant spell !
    Jun 2007
    North West
    434
    Thanks for the quick reply,Not noticed that option before - i can see options for them to come on earlier (threshold earlier), don't want this, want to decrease the sensitivity. On byte 1 there the light sensor correction which is set to 73% (mine a TT 8J), if I alter this setting (for different models), do I want to try a higher or lower percentage - brain just cant seem to work it out ?
    Richard
  1. Auto lights sensitivity - 8P3
    By BenC00 in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st February 2013, 11:02
  2. Auto lights
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2006, 11:10
  3. Flashing Auto Light Indicator
    By cadders in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2006, 10:39
  4. Adjusting normal lights
    By bunny in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th December 2005, 10:50
  5. Wierd timed / auto lights problem
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd March 2005, 19:47
