1 Fault Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 008 - Implausible Signal - Intermittent
Symptoms are ESP and EPC lights on dashboard and car in limp mode. Leaving car overnight renders the car back to normal the next day.
Seemed to only happen when the roads were damp and during a 1hour plus journey. Just happened on my way into work today which is a journey of 5miles and was in fine weather.
Have so far cleaned plug contacts on throttle body and also realigned throttle body. Happened again.
I'll be doing the same with the accelerator pedal this weekend.
Have had a nosey around the ecu box and it seems a little damp at the rear so will prob have that open to check for water ingress and also check and clean connections.
Ross tech website says it could be electrical connections, faulty accelerator pedal or faulty ecu. also mentions the o2 (lamda) senso could be the cause?? Car had a new lamda sensor in 2011 along with a new maf sensor.
Anything else to check???
