AH FabricationsJMB Retrofits
Results 1 to 9 of 9
    Sep 2012
    Grimsby, Lincolnshire
    72
    problems adapting a new key with VCDS on 8P
    I've got the full VCDS v11 and have followed the guide on rosstech for adapting a new fob (buttons only, not immobiliser).
    [Select]
    [46 - Cent. Conv.]
    [Adaptation - 10]
    Enter channel "01"
    [Read]
    This will display the number of currently stored remotes in "Stored Value".
    VCDS indicates that 1 fob is currently matched to the car
    Enter your total number of keys up to a maximum of 4(including any existing keys) in "New Value"
    I enter '2'
    [Test]
    seems to hang here?
    Verify that the number in "Test Value" is correct.
    test value never updates to '2'
    [Save]
    save button is greyed out, as I presume the test hasnt succeeded .
    Then press and hold (for at least one second) the UNLOCK button on the fob
    Does anyone have any suggestions?
    Jan 2011
    northants
    165
    erase the keys first then recode
    27,096
    Yeah that's what I do.
    Sep 2012
    72
    ok thanks, not sure what happened but the second fob just started working! I logged into VCDS again and it says 2 keys are paired.
    Just need to code in a new immobiliser chip now... I've got as far as getting the SKC with commander, and successfully logging into the Immobiliser [25] Security Access with the pin.
    Apr 2013
    I'm having this exact issue too. Car came with 2 keys and the spare works in the door and starts the car etc, but the remote doesn't function.
    VCDS shows 1 key learned and I can't update the value to 2. Scared to erase keys in case any problems occur while programming and I'm stuck with no remotes!
    Can someone 100% confirm that I have to erase the keys first, and if so, how do I do this?
    2005 A3 8P 3d 2.0 FSI
    Thanks in advance
    27,096
    You have no choice but to erase & add both keys.
    Apr 2013
    Thanks NHN. I did do it in the end. Car blinked to acknowledge both keys but key 2 still doesn't work. Very odd. Think I need to get a new remote on fleabay
    Jan 2013
    Moray
    228
    I'm having the same problem - a good friend of mine who works with vags says at times, they just die
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    Apr 2013
    Like everything I suppose!
    Odd how the car recognises it when learning though!
  1. coding keys with vcds?
    By glenandem in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th March 2013, 08:53
  2. Vag-Com problem on a new laptop with vista
    By Badgeronimous in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2007, 18:45
  3. New key problem
    By AlistairC in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2007, 22:54
  4. 89 Cabriolet (1993 model) - new owner with problems!
    By tonywitney in forum Classic Audi Forum
    Last Post: 15th August 2007, 22:55
  5. problem with immoobiliser deativation with new key
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd August 2004, 00:38
