Chris NottVolks Autos
Results 1 to 10 of 10
    Mar 2013
    10
    new to vagcom a3 8l need help please
    well i bought an audi a3 and thought id start simple and work up
    got ebay vag-com software was crap download a version 409-1 ?
    fitted dis stalk?
    connected to car now what?
    2002 A3 19 tdi sport
    and i have used the search and got pages and pages of cruise and dis fitting blah blah blah!! spent 3 days arsing around!
    tried to connect to 16 steering wheel but cant find module!
    tried 17 aswell still no luck!
    where do i enter code?
    what code?
    it cant be that hard ? can it?
    Mar 2013
    10
    nobody
    Sep 2007
    North-East UK
    96
    Could you post an autoscan so that we can see the modules that are available in your car?
    This information might allow people to see what your problem is and offer some help.
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels. Retrofit Armrest, Cruise Control & Gauge Sweep. VCDS.
    Jun 2011
    Great Melton Norfolk
    1,356
    If you are using a non genuine cable, you may only be able to scan for codes/faults .
    Also nongenuine cables and software are not discussed in this section as is for vcds licensed /lite users.
    May 2012
    RETFORD, NOTTS
    1,753
    Also, is there actually a full DIS display?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Mar 2013
    10
    Quote Originally Posted by @udi A3 View Post
    Ok what does the dis screen look like?
    My dash has time in the rev counter
    my display that shows petrol warning oil ok in the middle and then miles and trip on the speedo
    cant get the autos can to work it finds the first 2 modules then crashes out
    Jun 2011
    1,356
    DISis the lcd panel between the speedo and Tacho (rev counter) It gives info about car and warnings. Comes in 1/2 (top of panel is blacked out) and full size.
    I believe if you have half dis you cannot fit/use the stalk you have.
    Mar 2013
    10
    Now we are getting somewhere
    so I will need to replace clocks?
    And a module aswell?
    May 2012
    RETFORD, NOTTS
    1,753
    No, you will need to buy a proper vcds cable to post your scans, or get a member nearby to help out. Then determine the actual dash u have and the one you need to replace it with.
    Mar 2013
    10
    Think I will goto the vag meet tomorrow
  1. New Key Needed, Help Please :)
    By Adam-f in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th May 2011, 14:58
  2. New member needing help please
    By gm1308 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th March 2011, 10:50
  3. New owner of an A3...damaged it already! Need help please!
    By slants in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2010, 12:48
  4. Mis-sold my car? No of Owners - Need help please!
    By Mike_P in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2005, 12:23
  5. Need help please lovely people
    By imported_Beanflick in forum In-Car Entertainment
    Last Post: 5th March 2005, 16:18
