Sky InsuranceEM Tuning
Results 1 to 7 of 7
    Mar 2013
    West Yorksire
    24
    VCDS coding xenon to audi a3 2004
    Hi all, I need to code in my single Xenons i bought from ebay to my audi a3 2004 they are all fitted and sorted and work just need to code them in and make the dash warning light go away. I understand i have to go into to 09, CE module, and check on byte 21. Firstly the bytes did not go that far thus i entered 00 untill it go to byte 21 and selected the option on xenons from the drop down menu and copied the long code and when i tried to enter this back on to it did not allow me too save the code. Are the options different on an 2004 A3? Thanks in advance
    26,749
    Log of the car would help.
    Mar 2013
    West Yorksire
    24
    I will try get one up asap but does not help as i'm using my employers cable at there garage.
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    430
    Subscribed, i will be doing this shortly to my A3 which is also a 2004 but mine already has xenons so hoping the CE supports it!.
    Mar 2013
    West Yorksire
    24
    Turns out i don't have byte 21 , How can i tackle this ?
    26,749
    As advised before, provide a log so we can see what modules are installed.
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    430
    Slight thread hijack but NHN could you please advise on mine mate for bi-xenon ? : part of the scan.
    Shop #: WSC 00000 000 00000
    VCID: 2F676218C78D
    No fault code found.
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H30 0501
    Revision: 00030000 Serial number: 00000000403829
    Coding: 038A4F00A2141000000000000000000000
    VCID: 3B7F464803F5
    Part No: 8P2 955 119 A
    Component: Wischer WWS Audi350 0170
    Coding: 16711696
    Shop #: WSC 00000
    1 Fault Found:
    00924 - Relay for Headlamp Cleaning System (J39)
    009 - Open or Short to Ground
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011602
  1. Audi S3 8L VCDS codes H12 alarm related
    By Andyrew_69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2013, 18:40
  2. Audi A3 8P2 VCDS Coding
    By zippyijk in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th June 2012, 00:20
  3. Audi a3 2.0 tdi 2004 8p coding xenon headlights
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th November 2011, 16:40
  4. Audi DRLs now not working - VCDS coding error
    By vagcat in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th July 2011, 20:48
  5. Single xenons oem for audi a3 2004 Simple swap for halogens?
    Last Post: 22nd February 2011, 19:25
