fault code help
mehtaman
Wembley, Middlesex
Hi All,
I ran a full scan on my car and received a few faults, could someone please take a look at them and let me know what may need fixing...
Navigation
Code:
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 8E0 035 192 T    HW: 8E0 035 192 T
   Component: RNS-E HIGH EU   H74 0650
   Revision:      05S
6 Faults Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
00446 - Function Limitation due to Under-Voltage
00878 - Connection to Speaker Front Left
            011 - Open Circuit
00879 - Connection to Speaker Front Right
            011 - Open Circuit
00857 - CD Changer Unit (R41)
            004 - No Signal/Communication - Intermittent
02005 - Coding Pin
Central Conv.
Code:
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 CQ
   Component: Komfortgerát T3B    4336
   Subsystem 1 - Part No: 8E2959802F
   Component: Tõrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E2959801F
   Component: Tõrsteuer.BF BRM 0606
   Subsystem 3 - Part No: 8E0959801E
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
00962 - Alarm via. Tilt Sensor
            35-00 -  -
Radio
Code:
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Revision:      05S
6 Faults Found:
            011 - Open Circuit
            011 - Open Circuit
02005 - Coding Pin
Park Assist
Code:
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 E    HW: 8E0 919 283 E
   Component: Parkhilfe 8-Kan H06 0010
   Revision: 00H06000
1 Fault Found:
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
NB: I have ommited some details such as serial numbers and coding IDs.
Many Thanks!
check the codes on the wiki
Thanks Bez101
6
3K
4K
320
