Sky InsuranceVolks Autos
Results 1 to 9 of 9
    Oct 2012
    Warrington, North West
    953
    Help with a scan
    Can somebody please give me a lowdown for these faults, the only ones I'm aware of is the door puddle/warning lights
    VCDS Version: Release 11.11.5 (x64)
    Data version: 20121222
    Wednesday,06,March,2013,21:14:13:46857
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 76 7D
    VIN: WAUZZZ8P26A067783 Mileage: 136330km/84711miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    76-Park Assist -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 DT HW: 028 101 189 2
    Component: R4 2,0L EDC G000AG 7000
    Revision: 12345678 Serial number: AUX7Z0E8FNC05I
    Coding: 0000078
    Shop #: WSC 06314 000 00000
    VCID: 78F9AE1D0B6442D819C
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 042 F HW: 02E 927 770 AE
    Component: GSG DSG 070 0920
    Revision: 04507000 Serial number: 00000508260516
    Coding: 0000020
    VCID: 162580A5213094A8EB0
    1 Fault Found:
    18255 - Please check DTC Memory of ABS Controller
    P1847 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Reset counter: 1
    Mileage: 136190 km
    Time Indication: 0
    Date: 2013.02.28
    Time: 23:50:27
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
    Component: ESP FRONT MK60 0102
    Revision: 00T12001
    Coding: 0023170
    VCID: 408906FD1334CA1861C
    1 Fault Found:
    01435 - Brake Pressure Sensor 1 (G201)
    012 - Electrical Fault in Circuit
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
    Component: KlimavollautomatH17 0200
    Revision: 237714 Serial number: 8P0820043H
    VCID: 316F5339A89E53909E2
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H36 1201
    Revision: 00H36000 Serial number: 00000002179263
    Coding: 05884F00B214100000160000160000000008FE175C0100
    Shop #: WSC 06314 000 08192
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    10 Faults Found:
    01493 - Bulb for Blinkers; Front Left (M5)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 15:00:00
    Freeze Frame:
    ON
    Voltage: 11.25 V
    ON
    ON
    OFF
    OFF
    OFF
    01497 - Bulb for Blinkers; Front Right (M7)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 15:00:00
    Freeze Frame:
    ON
    Voltage: 11.25 V
    ON
    ON
    OFF
    OFF
    OFF
    00988 - Lamp for Brake Light; Right (M10)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 16
    Reset counter: 196
    Mileage: 135416 km
    Time Indication: 0
    Date: 2013.02.03
    Time: 16:00:00
    Freeze Frame:
    ON
    Voltage: 14.20 V
    ON
    ON
    OFF
    OFF
    ON
    02394 - Parking Light Left Front (M1)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 15:00:00
    Freeze Frame:
    ON
    Voltage: 11.30 V
    ON
    ON
    OFF
    OFF
    OFF
    02395 - Parking Light Right Front (M3)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 15:00:00
    Freeze Frame:
    ON
    Voltage: 11.30 V
    ON
    ON
    OFF
    OFF
    OFF
    02071 - Local Databus
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.10
    Time: 11:39:00
    Freeze Frame:
    OFF
    Voltage: 11.55 V
    OFF
    ON
    OFF
    OFF
    OFF
    01499 - Bulb for High-Beams; Right (M32)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 15:00:00
    Freeze Frame:
    ON
    Voltage: 11.30 V
    ON
    ON
    OFF
    OFF
    OFF
    00978 - Lamp for Low Beam; Left (M29)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 172
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 15:00:00
    Freeze Frame:
    ON
    Voltage: 11.30 V
    ON
    ON
    OFF
    OFF
    OFF
    00979 - Lamp for Low Beam; Right (M31)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 15:00:00
    Freeze Frame:
    ON
    Voltage: 11.30 V
    ON
    ON
    OFF
    OFF
    OFF
    00153 - Windshield Wiper Motor; Driver Side (V216)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 11.55 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H12 3760
    Revision: 91H12376 Serial number: 00362004CKCG
    Coding: 0074622
    VCID: 428D0CF51D38D808778
    3 Faults Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 17
    Reset counter: 164
    Mileage: 131912 km
    Time Indication: 0
    Date: 2012.10.21
    Time: 17:27:26
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 15:00:03
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 135015 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 15:00:04
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 E HW: 8P0 953 549 E
    Component: Lenksäulenmodul H34 0070
    Coding: 0011142
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H03 0080
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
    Component: KOMBIINSTR. VDO H80 0410
    Revision: D03 Serial number: 2248ED03005317
    Coding: 0000443
    Shop #: WSC 54064 210 66681
    VCID: 377B6D2146FA8DA0D06
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 F HW: 1K0 907 951
    Component: Gateway H10 0120
    VCID: 2A5D4455854820485F8
    Part No: 1K0 907 530 F
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D03 Serial number: AUX7Z0E8FNC05I
    Shop #: WSC 00006 210 89785
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0070
    Coding: 0000760
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 J
    Component: EPS_ZFLS Kl.5 D04 1606
    Shop #: WSC 00000 000 00000
    VCID: 3363593152826180ECE
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 198000186D088505489FC63300
    VCID: 3C71720D7FDCAEF83D4
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    2 Faults Found:
    00956 - Key 2
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    01565 - Luggage Compartment Light (W3)
    007 - Short to Ground - Intermittent
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH04 0180
    Revision: 00003 Serial number: 30674526030592
    VCID: F1EF1339E81E93905E2
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000760
    VCID: 418F03F9183EC3106E2
    Address 56: Radio Labels: 8P0-035-1xx-56.lbl
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H52 0100
    Revision: 02S Serial number: AUZ2Z3E2886070
    Coding: 0001003
    Shop #: WSC 06435 000 00000
    VCID: 326D5C35AD986888E78
    1 Fault Found:
    00857 - CD Changer Unit (R41)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 49
    Mileage: 131516 km
    Time Indication: 0
    Date: 2012.09.13
    Time: 04:50:20
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0060
    Coding: 0000216
    1 Fault Found:
    00122 - Outside Warning Light/Door exit Light; Rear Left
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000216
    1 Fault Found:
    00123 - Outside Warning Light/Door exit Light; Rear Right
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
    Component: Parkhilfe 4-Kan H09 0010
    Revision: 00H09000 Serial number: 00067824820524
    Coding: 0001013
    Shop #: WSC 131071 1023 2097151
    VCID: 397F6B1970EE9BD0262
    1 Fault Found:
    01543 - Parking Aid Warning Chime (H15)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 135528 km
    Time Indication: 0
    Date: 2013.02.06
    Time: 21:01:20
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D574F49B4A63770BAA
    26,720
    The G201 abs module error is worrying, clear all faults & drive car then rescan.
    brasiliangringo's Avatar
    Mar 2010
    496
    Many of them are as a result of low voltage, sets all sorts of things off eg address 09, you are 11.30V which is too low and airbags 15 is showing a low voltage code to..
    Oct 2012
    953
    Help with a scan
    I'm getting the g201 looked at I think it needs the repair kit, and how do I sort this low voltage?
    26,720
    Have you cleared the faults & rescanned with car running?
    Oct 2012
    953
    Help with a scan
    Gonna do it in a minute, you mean fire the car up let it idle?
    26,720
    Yes
    Oct 2012
    953
    Help with a scan
    Cleared faults all gone bar the abs and radio cd changer, and a fault on auto trans saying check abs DTC so I'm guessing there there linked to my abs pump?
    26,720
    Yes, related to abs fault.
  1. Anyone help with a VCDS scan south coast, Portsmouth-Brighton
    By RyanW in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th July 2012, 15:35
  2. Help with VCDS scan
    By fad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th December 2010, 01:09
  3. Help with VAGCOM scan. EGR System
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th November 2009, 20:03
  4. Help with fitting SYMPHONY double-din head unit
    By excursion in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2003, 21:29
  5. Please I need help with spacers!!!
    By nianmuzik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 22:44
