Can somebody please give me a lowdown for these faults, the only ones I'm aware of is the door puddle/warning lights
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Wednesday,06,March,2013,21:14:13:46857
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 76 7D
VIN: WAUZZZ8P26A067783 Mileage: 136330km/84711miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC G000AG 7000
Revision: 12345678 Serial number: AUX7Z0E8FNC05I
Coding: 0000078
Shop #: WSC 06314 000 00000
VCID: 78F9AE1D0B6442D819C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 F HW: 02E 927 770 AE
Component: GSG DSG 070 0920
Revision: 04507000 Serial number: 00000508260516
Coding: 0000020
VCID: 162580A5213094A8EB0
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Reset counter: 1
Mileage: 136190 km
Time Indication: 0
Date: 2013.02.28
Time: 23:50:27
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0023170
VCID: 408906FD1334CA1861C
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH17 0200
Revision: 237714 Serial number: 8P0820043H
VCID: 316F5339A89E53909E2
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002179263
Coding: 05884F00B214100000160000160000000008FE175C0100
Shop #: WSC 06314 000 08192
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
10 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.25 V
ON
ON
OFF
OFF
OFF
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.25 V
ON
ON
OFF
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 16
Reset counter: 196
Mileage: 135416 km
Time Indication: 0
Date: 2013.02.03
Time: 16:00:00
Freeze Frame:
ON
Voltage: 14.20 V
ON
ON
OFF
OFF
ON
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Right Front (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.10
Time: 11:39:00
Freeze Frame:
OFF
Voltage: 11.55 V
OFF
ON
OFF
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 172
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 11.55 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H12 3760
Revision: 91H12376 Serial number: 00362004CKCG
Coding: 0074622
VCID: 428D0CF51D38D808778
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 17
Reset counter: 164
Mileage: 131912 km
Time Indication: 0
Date: 2012.10.21
Time: 17:27:26
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:03
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:04
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 E HW: 8P0 953 549 E
Component: Lenksäulenmodul H34 0070
Coding: 0011142
Part No: XXXXXXXXXXX
Component: Lenkradmodul H03 0080
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
Component: KOMBIINSTR. VDO H80 0410
Revision: D03 Serial number: 2248ED03005317
Coding: 0000443
Shop #: WSC 54064 210 66681
VCID: 377B6D2146FA8DA0D06
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
VCID: 2A5D4455854820485F8
Part No: 1K0 907 530 F
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D03 Serial number: AUX7Z0E8FNC05I
Shop #: WSC 00006 210 89785
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0070
Coding: 0000760
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Shop #: WSC 00000 000 00000
VCID: 3363593152826180ECE
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000186D088505489FC63300
VCID: 3C71720D7FDCAEF83D4
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
2 Faults Found:
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
01565 - Luggage Compartment Light (W3)
007 - Short to Ground - Intermittent
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674526030592
VCID: F1EF1339E81E93905E2
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000760
VCID: 418F03F9183EC3106E2
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3E2886070
Coding: 0001003
Shop #: WSC 06435 000 00000
VCID: 326D5C35AD986888E78
1 Fault Found:
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 49
Mileage: 131516 km
Time Indication: 0
Date: 2012.09.13
Time: 04:50:20
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0060
Coding: 0000216
1 Fault Found:
00122 - Outside Warning Light/Door exit Light; Rear Left
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000216
1 Fault Found:
00123 - Outside Warning Light/Door exit Light; Rear Right
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
Component: Parkhilfe 4-Kan H09 0010
Revision: 00H09000 Serial number: 00067824820524
Coding: 0001013
Shop #: WSC 131071 1023 2097151
VCID: 397F6B1970EE9BD0262
1 Fault Found:
01543 - Parking Aid Warning Chime (H15)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 179
Mileage: 135528 km
Time Indication: 0
Date: 2013.02.06
Time: 21:01:20
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D574F49B4A63770BAA
Chassis Type: 1K0
Coding: 0000078
Coding: 0000020
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Reset counter: 1
Mileage: 136190 km
Time Indication: 0
Date: 2013.02.28
Time: 23:50:27
Revision: 00T12001
Coding: 0023170
1 Fault Found:
Coding: 00062736
Shop #: WSC 06314
10 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.25 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.25 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 16
Reset counter: 196
Mileage: 135416 km
Time Indication: 0
Date: 2013.02.03
Time: 16:00:00
Freeze Frame:
ON
Voltage: 14.20 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.10
Time: 11:39:00
Freeze Frame:
OFF
Voltage: 11.55 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 172
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:00
Freeze Frame:
ON
Voltage: 11.30 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 11.55 V
OFF
ON
OFF
OFF
OFF
Coding: 0074622
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 164
Mileage: 131912 km
Time Indication: 0
Date: 2012.10.21
Time: 17:27:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 135015 km
Time Indication: 0
Date: 2013.01.04
Time: 15:00:04
Coding: 0011142
Coding: 0000443
No Faults Found
Coding: 0000760
2 Faults Found:
00956 - Key 2
Coding: 0000760
Coding: 0001003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 49
Mileage: 131516 km
Time Indication: 0
Date: 2012.09.13
Time: 04:50:20
Coding: 0000216
1 Fault Found:
Coding: 0000216
1 Fault Found:
Coding: 0001013
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 179
Mileage: 135528 km
Time Indication: 0
Date: 2013.02.06
Time: 21:01:20
