Volks AutosMonster Motorsport
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By bearthebruce
Thread: VCDS cable on other OBD-II vehicles
    Jan 2013
    Moray
    228
    Hi all,
    Tempted to buy genuine VCDS cable from ross-tech, although my next question - If i had other software for OBD-II to scan other cars, would the cable still work?
    Steve
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    26,762
    Hey Steve, it will only work on vag cars, which is fairly comprehensive as it is.
    I sell the genuine RT cables, send me a PM if interested, cheaper than importing from them direct, same product aswell with same support & updates.
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Re: VCDS cable on other OBD-II vehicles
    Speaking from a nhn customer standpoint...
    The supplied cable will read a lot of cars, but only obd compliant stuff. So no airbags, abs, coding etc.
    But will read and clear eml, and pull data list info, but again, only obd.
    The stuff the manufacturers have to make available time non dealer scanners.
    If you mean you want to use say BMW's inpa, dis, ediabas or something similar for another brand, with the supplied cable. I dont know what it would do.
    I've wondered this myself.
    I think the cable has some gadgetry in it, specific for vag, which is why the cheapy eBay ones don't work fully. So I would think other brands would need something similar?
    Hope this is Ok Nigel, I know you can hardly advise it for anything but what it's sold for. Just offering my experience with it.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    326
    Quote Originally Posted by Rom View Post
    It will not work. The internal settings of the microcontroller will not allow it to speak with other software brands. There were a couple old packages around that if you switch the interface to "dumb" mode will work. But, fewer and fewer of those do.
    As we have to up the protection on our devices to slow the cloners down - not that that has worked! - it makes our devices less friendly to other software packages.
    Indeed!
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    My mate tested his cable on his mum's fiat and it worked.
    Just read the fault codes.
    So not bad going really.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Yeah, I've read engine related codes on vauxhall, bmw, Ford, toyota, probably more.
    But obd is only emissions / engine related. Anything else falls outside, and is generally locked away by manufacturers .
    It's helpful for me regardless, I do a lot of side jobs, so always handy.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    26,762
    If its plugged into a non vag car, then that would void the warranty afaik & therefore have no recourse to be swapped out, so I cant advise on anything but the systems it was designed to work with fully, so to avoid any issues with this, its better to stay within the confines of the products guaranteed features as such.
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    326
    Seems either I have missed the point or others are missing the point....
    So let me more clear: VCDS interfaces will not be damaged if plugged into any un-modified (read that factory configured) OBDII DLC connector. It may not talk to all cars but it will not be damaged by plugging them into another brand.
    The question I answered earlier I thought was discussing whether a Ross-Tech interface could be used with other software. The answer to that question is no (or not likely) and indeed the Ross-Tech interface may be damaged if one tries to run other software using our interfaces.
    Does that clear things up?
    ScottD3 likes this.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Makes sense to me...I'm on the same page. I've tried and tested what you said first.
    And have just wondered about the other brand software. But as I said earlier, figured it wouldnt work.
    2004 A3 TDi Sport
    Past Cars
    BMW E46 330d Sport
    VW Gold MK4 TDi
    Jan 2013
    Moray
    228
    Crikey, wasn't expecting such an answer! I merely want to know if i would be able to read fault codes and cancel them, my other half has a 2002 toyota Rav 4, just seems a lot of money to spend on a cable that will only work on VAGs.
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    326
    Steve220, then it sounds like what you want is a generic OBDII scanner which will give you access to emissions related systems and report a subset of information from your engine. You should be able to pick that up for under £50ish..
    VCDS is a factory level diagnostic tool - designed specifically for VAG cars. It accesses all electronic modules and pulls all fault information from the car. I hope that helps delineate the differences.
    VCDS does have generic OBD support but there are two flavors of the standard. VAG uses one. The Detroit 3 uses another. And the Asians are split between the two. You can try it on the 2002 RAV 4.. (My foggy head does not remember if I used it on my wife's '08 Rav4 - but that car is CAN.) And I should mention that in 2008, in the US and I believe all across the world, all moved OBDII to CAN. That means that any CAN based VCDS interface can and will speak generic OBDII with any '08 and newer car.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Jan 2011
    Aberdeenshire
    633
    My KII lead worked on the BMW Bentley for OBD-II, engine code reading and clearing. I would expect it to work on the BMWs for the same thing.
    (I WILL do a full port scan of the Bentley one day - it's only been a year or so since you - Ross-Tech - answered my e-mail, sorry Bruce!)
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    Jan 2013
    Moray
    228
    Seems as if no one really truly knows the answer to my question. I'll give it a miss. Too much money for a cable IMO.
    26,762
    Quote Originally Posted by Steve220 View Post
    Its not the cable so much, its the software it utilises, what it can do is for me quite brilliant, I use mine daily & never had an issue, it even does few things the dealer cant as well
    Dealer vas/odis £5-10k vs Vcds £260, maths doesn't need to much thought
    Also dealer systems charge thousands yearly for updates, to date vcds updates have been free.
    Jan 2013
    Moray
    228
    That maybe so, but I don't want to alter my car everyday, just to code the new RNS-E, cruise control and maybe a new remote, the rest of it is pretty much useless to me.
    26,762
    Ironically after this discussion me & a mastertech friend were working on a hybrid turbo for an A3 & he said, my cars got an engine light up, shall we test with vcds, so we plugged in & used the odb facility, low & behold it worked a treat on his Evo 8, read some sensors & he cleared the light, very impressed tbh, very surprised, way to go RT.
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    568
    Best £250 ive spent. The potential to earn back what you spent, cheaper in the long run instead of having to pay someone else or a stealer, and retro fits are no longer a hesitation in my mind because i can code it.
    And as it becomes more apparent it may actually work with other OBD cars, obviously not coding.. But for reading faults and clearing them.
    May 2012
    RETFORD, NOTTS
    1,707
    I think Bruce answered your question along with several others quite clearly. Generic OBDII this is not, if that's what you need don't buy VCDS
    Price up this job with the local dealer. Then maybe pm NHN as he seems to do this in his sleep, and get a quote for the work. Then find somebody closer to home if NHN is too far, with the skill and know-how to carry out the work in a competent manner.
    If you cant, then suddenly the cable becomes worth more to you, and if there is nobody local offering this kind of service, there is opportunity to help you recoup the cost offering the service. My cable has paid for itself in personal work and probably again helping others with scans/coding/adaptions. Just yesterday my alarm wigged out, so VCDS diagnosed the fault and i managed to prevent the car making loud noises all night!
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Genuine VCDS cable and Laptop.
    By Viking in forum For Sale/Wanted - Miscellaneous
    Last Post: 25th April 2012, 19:03
  2. how can i tell if 2nd hand vcds cable is genuine
    By DeviousG in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd April 2012, 20:44
