Sky InsuranceJMB Retrofits
Results 1 to 8 of 8
    I cant spell !
    Jun 2007
    North West
    434
    Boot release button disable on door
    I've some how managed to disable the boot release via the button on door of my MK2 TT, probably by my messing with vag com
    It still works on the remote key fine, as does the fuel release button next to the boot release on the door.
    Any idea where to undo this in vag com
    Thanks in advance
    Richard
    MY12 Black edition TT Roadster with a tractor engine !
    27,096
    Did you have a log of the car before you changed anything?
    I cant spell !
    Jun 2007
    North West
    434
    Lol that would have been far too sensible of me !
    After 6 years of messing with vag com just found out that the log files can be used as a backup.
    I'm going to take the door panel off when I have time to see if I have not connected something back when I put the puddle lights in, but I doubt this as the fuel release works and the switch lights up as normal. - Hence why I think its something I've done in vag com
    Richard
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    Richard, post up a full scan of the as it is currently coded, I will compare it to SWMBO’s MY11 TT.
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
    I cant spell !
    Jun 2007
    North West
    434
    Gizmo do you post on TTforum as well ?
    This is an auto scan I did last night - fingers crossed I did this right
    Chassis Type: 8P0
    Scan: 01 03 08 09 10 15 16 17 19 22 25 26 42 44 46 47 52 55 56 61
    77
    VIN: XXXZZZ8JXXXXXXXXX
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    26-Auto Roof -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 DT HW: 03L 906 018 DT
    Component: R4 2,0L EDC H23 7766
    Revision: 42H23--- Serial number: AUX7Z0K2FNH00I
    Coding: 00190012042700080000
    Shop #: WSC 01236 785 00200
    ASAM Dataset: EV_ECM20TDI01103L906018DT 003004
    ROD: EV_ECM20TDI01103L906018DT.rod
    VCID: 7F23CAFDE6E4F3E0586
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8J0-614-517.clb
    Part No SW: 8J0 614 517 B HW: 8J0 614 517 B
    Component: ESP MK60E1 0010
    Revision: 00H60001
    Coding: 0083827
    VCID: 2C79CDB18F12B878AD4
    Address 08: Auto HVAC Labels: None
    Part No SW: 8J0 820 043 BB HW: 8J0 820 043 BB
    Component: J255 Klima 1 Zone 0110
    Revision: 00H09006 Serial number: 00000001181735
    Coding: 1049876
    VCID: 67F3729D56745B20806
    Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
    Part No SW: 8P0 907 063 H HW: 8P0 907 063 H
    Component: BCM PQ35 H 108 0615
    Revision: 00108 AG
    Coding: 4600012FE205F1202070E8E00180894C577E58AA3120D128DC 000E440045
    Shop #: WSC 01236 758 00200
    VCID: 3957E4E5B0401DD0262
    Subsystem 1 - Part No SW: 8J2 955 119 A HW: 8J2 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer AU354 H08 0070
    Coding: 00FD10
    Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSEN H04 0003
    Coding: 02492C
    Subsystem 3 - Part No: 8J0 951 177
    Component: DWA-Sensor H0 H03 0030
    Subsystem 4 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
    Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
    Component: PARKHILFE 4K H01 0140
    Revision: 11001001 Serial number: 36891108157146
    Coding: 00000B
    VCID: 48B19121FBAA7458A9C
    Address 15: Airbags Labels: 8J0-959-655.lbl
    Part No SW: 8J0 959 655 HW: 8J0 959 655
    Component: -t Airbag 9.43 H03 0020
    Revision: 93H03002 Serial number: 0036K00551JG
    Coding: 0011636
    VCID: F9D7A4E5B0C05DD0E62
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H37 0070
    Coding: 0003041
    VCID: 46AD9F1931BE62285B0
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    Address 17: Instruments
    Cannot be reached
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 8P0 907 530 C HW: 1K0 907 951
    Component: J533 Gateway H43 0311
    Revision: H43 Serial number: 280311F1003066
    Coding: 355101
    VCID: 334BD6CD922CE780ECE
    Address 22: AWD Labels: Redir Fail!
    Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
    Component: Haldex 4Motion 3017
    Coding: 0000005
    Shop #: WSC 00000 000 00000
    VCID: 44A9851107825038454
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Part No SW: 8J0 920 980 R HW: 8J0 920 980 R
    Component: KOMBIINSTR. VDO H01 0591
    Revision: D0H01004 Serial number: AUX7Z0K2FNH00I
    VCID: 40A18901139A4C1861C
    Address 26: Auto Roof Labels: 8J7-959-255.lbl
    Part No: 8J7 959 255 D
    Component: 256 VSG TT H18 0150
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 8J7 959 801 N HW: 8J7 959 801 N
    Component: Tuer-SG H04 0101
    Coding: 0000630
    VCID: 47B3921D36B47B20A06
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 8J0 909 144 M
    Component: EPS_ZFLS Kl. 236 3201
    Revision: 00H20000
    VCID: 3A55FBE9754616C82F8
    Address 47: Sound System Labels: 8J0-035-223.lbl
    Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
    Component: J525 Amp High H04 0160
    Revision: PROD_01 Serial number: 00000000025470
    Coding: 0136133
    VCID: 256F3895ECF8893072A
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 8J7 959 802 N HW: 8J7 959 802 N
    Coding: 0000628
    VCID: 48B191213BAA7458A9C
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P3 907 357 B
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000010
    VCID: 3C59FDF17F7228F83D4
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8J0 035 195 G HW: 8J0 035 195 G
    Component: R Symphony2+ H08 0281
    Revision: 00H08000 Serial number: AUZ1Z4L0545527
    Coding: 0730301
    VCID: 3041D9C1A33ADC9891C
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 8P0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H43 0311
    Coding: F302015A
    VCID: F4C995D157A220B8B54
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0140
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 HW: 8P1 862 335
    Component: FSE_256x BT H41 0650
    Revision: 00000000 Serial number: 00000005360296
    Coding: 0001202
    VCID: F4C995D197A220B8B54
    Richard
    27,096
    Login to module 09 & there will be a long coding option to resolve this as afaik, you have the newer 063 ce module in 09, so all conv module functions are in 09 now, not 46.
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    85
    Yes I am also on the TT forum.
    As the car was purchased:
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8J8 959 801 H HW: 8J8 959 801 H
    Coding: 0004661
    VCID: 4280FFFF1D94F03
    This was later changed to:
    Coding: 0004725 when the puddle and door opening warning lights were added.
    I have also coded another 60 plate TDi TT which was:
    Coding: 0004733
    VCID: 4280FFFF1D94F09
    Note these both use a slightly different part number for the door controller.
    I will check the car tomorrow to see what each coding does on thhe car.
    MY11 Audi TT TDi
    I cant spell !
    Jun 2007
    North West
    434
    Thank you - I will have another look at the car tonight and see if anything looks obviously wrong.
    I do have the orig setting for each door - as I took a picture of the setting before I changed them - lazy I know !
    0-8j7 959 802N Tuer SG H04 0101
    Software coding for drivers was 0000565 -
    passenger was 0000564 -
    I added 64 to each of these value to get the puddle lights to work.
    I will try re in putting the orig setting to see if the boot release works.
    Richard
  1. boot release button
    By tomstanley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2010, 17:40
  2. Audi A3 2002 - boot release broken ..
    By adigraham in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th March 2007, 10:30
  3. button on drivers door inner seal...
    By Welch in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2005, 18:06
  4. reomte boot release / opening - how far should it open?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2005, 09:31
  5. Hatch release button
    By imported_HEADACHEZ in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd June 2004, 20:30
