    Mar 2013
    5 Beeps on Startup after VCDS mod
    Hi all
    Iam driving a Audi a4 (b8) 2.0 TFSI 2011 and just added gauge needle sweep and after that mod the car gives 5 beeps on each startup every time?
    Have I missed anything? used long coding helper and ticked the box under instrument cluster
    Best Regards
    Marcus
    Jan 2012
    1,837
    Does it do it if you remove the needle sweep?
    Mar 2013
    Its still there after I put i back to normal
    Jan 2012
    1,837
    Any faults present?
    Post an autoscan.
    Mar 2013
    Address 17:8K0 920 930 M recoded (Long Coding) from 0F04090002000008010000 to 0B05090002000008010000 (06325/000/00000) Wednesday,27,February,2013,19:52:45:37412
    Address 17:8K0 920 930 M recoded (Long Coding) from 0B05090002000008010000 to 0B04090002000008010000 (06325/000/00000) Wednesday,27,February,2013,19:57:54:37412
    Address 17:8K0 920 930 M recoded (Long Coding) from 0B04090002000008010000 to 0B01090002000008010000 (06325/000/00000) Wednesday,27,February,2013,19:58:35:37412
    Address 17:8K0 920 930 M recoded (Long Coding) from 0B01090002000008010000 to 0B04090002000008010000 (06325/000/00000) Wednesday,27,February,2013,20:01:32:37412
    Could I use 0F04090002000008010000 and copy it into the long coding to be able to go back from the start?
    Ill make a Autoscan tomorrow if aint possible to reverse it with 0F04090002000008010000.
  1. Hill Hold Assist VCDS Mod
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2014, 11:35
  2. Blue smoke for 2 seconds on startup after 1 week of not running... Worried or Not??
    By kevin00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2011, 18:08
  3. Beep on Startup
    By XPOWER in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd January 2011, 17:14
  4. S3 0-60 after remap (mods to put in faq perhaps??)
    By nky_84 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2008, 09:07
  5. After run mod S4
    By s4mark in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2007, 17:33
