Sky InsuranceChris Nott
    epox's Avatar
    Oct 2012
    Glasgow
    560
    is it Possible to check for mileage with vcds
    hi team
    as above.
    and how to if poss on a 2003 s3.
    thanks mark
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Yes.
    Via the Engine 01.
    Its in kph.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    27,011
    Not sure if the cluster & ecu share the same reading as such on your car tbh, but the 8P 2.0 tdi has cluster mileage & ecu mileage, so if someone clocks it, the ecu will differ from cluster, ideally you need to ask RT with your engine code & an autoscan as cant be sure for all engine codes & years I'm afraid.
    May 2012
    RETFORD, NOTTS
    1,748
    None of my cables retreive milage from the ecu, but I can change the milage on the cluster.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Checking genuine mileage using VCDS ??
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2014, 13:44
  2. is it Possible to check for mileage with vcds
    By epox in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2013, 21:06
  3. Possible to check for"mileage correction" via vag com?
    By tedward in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th August 2012, 23:22
  4. Checking mileage with VagCom?
    By jojo in forum General Automotive Chat
    Last Post: 24th October 2011, 10:36
  5. Anyone fancy a custom Milltek for A3 with S3 Bumpe
    By nfluester in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 10:31
