Results 1 to 15 of 15
    glenandem's Avatar
    Sep 2012
    manchester
    528
    coding keys with vcds?
    is it poss to code the actual key chip with vcds if i have the skc number?
    i know you can code the remote side but just wondered about the actual immobiisor bit?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    yes if yiu have the SKC
    Oct 2012
    Warrington, North West
    986
    What's an skc and how do you get it?
    Jun 2011
    Great Melton Norfolk
    1,349
    SKC is the code required to access immobiliser coding in instruments. It used to be on a small scratch off card, but after a certain year you can only get from dealer as they have to connect to Audi Germany and the code is sent to the car. The Dealer willnot be able to give you the code.
    Oct 2012
    986
    So it's not possible to code your own key?
    Jun 2011
    1,349
    Yes you can , if you have the code and vcds and the car is before 2005/6, After that its Main Dealer job.
    May 2012
    RETFORD, NOTTS
    1,753
    Sometimes the SKC is retrievable with other cables/software to VCDS, but not with VCDS itself.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Oct 2012
    986
    I bet that software and cable costs a fortune?
    Jun 2011
    1,349
    NHN sells VCDS on here pm him for a price.
    Jun 2011
    1,349
    vagtacho should be able to retrieve, but not after 2005/6
    Oct 2012
    986
    I meant the software for pulling codes, and already spoke to him, he's awaiting delivery of stock
    May 2009
    south yorkshire
    628
    depends on the year of the car and what clocks you have , i can retrieve skc codes sometimes via obd other times by removing eprom from clocks and reading in a programmer
    glenandem's Avatar
    Sep 2012
    manchester
    528
    is it poss to recover the skc on a 1.9tdi ecu with vagtacho,if i can get it with that then hopfully i can code the key in with vagcom!
    May 2012
    RETFORD, NOTTS
    1,753
    I can pull my 1.9tdi pin with commander i think. i have tacho and commander though, my A6 uses tacho. I think its a bit hit and miss as im using cheepo ebay cables, but was only for that purpose and to do the miles to empty on a buddies car. VCDS genuine for everything else.
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    300
    Add craigynett on Google+
    even with the SKC you're not going to be able to program a new key to a 2005/6 onwards VAG because the transponder has to be pre-coded with CS (compenent security) info before it can be programmed to the car. Pre-coding equipment is expensive so definitely not worth it for somebody who wants to do 1 key to their own car.
    I've got 2 different bits of equipment that will pre-code transponders. Pre-coding is basically making a dealer key without going to the dealers
    Please contact Admin if you wish to advertise your business/services on the forum
  1. Key Coding with VCDS Report , Expert Required!!
    By Blacky165 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2012, 15:46
  2. coding wiper motor with VCDS
    By andrewyzfr6 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2012, 16:58
  3. ABS module won't code with VCDS???
    By BILKO1 in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th February 2011, 07:01
  4. A3 Key with light, what battery does it take.
    By Zenin in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2009, 20:33
  5. Only one key with car
    By AndyCollins in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th May 2004, 22:53
