Volks AutosChris Nott
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By PAULF
Thread: DIS Fuel Consumption Correction?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,870
    I'm almost sure I read a guide on how to calibrate the DIS fuel consumption figures with VCDS to be more accurate than factory settings! I've searched, but can't seem to find it.
    Can anyone link me to the article, or better yet, post a quick guide.
    Thanks.
    2009 A3 SB 2.0T DSG S line
    Jan 2011
    Aberdeenshire
    646
    I have done this a couple of times and had no trouble, and thus can't remember!!
    I'm sure if you hover over the setting, a bubble comes up with the 'formula' to calculate which way to go.
    I also think Ross-Techs site has it somewhere.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Jan 2011
    Aberdeenshire
    646
    Ok, just to expand on the above:-
    For the A4 B5, go to 17 Instruments, 10 Adaption, Channel 03.
    Hover over the value (factory is 100%) and the bubble explains how to calculate the required new value. (I've come in now and forgotten already!!)
    You can adjust it 85% to 115% of the factory value.
    Artimus likes this.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,870
    Thanks Paul,
    so just to make sure I understand the way this works: upping the percentage will up the max range, for instance, or lower it?
    Jan 2011
    Aberdeenshire
    646
    I keep forgetting - that's how I knew about the pop-up!
    I've just gone out and checked, and the new value is the old value (probably 100 if not changed before) multiplied by the DIS MPG, divided by the calculated MPG
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,870
    I'll have a play when I get time this weekend.
    Thanks again for taking the time to check it out - above and beyond the call of duty.
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    Upping the percentage lowers the MPG,
    on the cars i have calibrated 1MPG = 2%, so if the DIS was reading 5MPG over the actual figure, raise the 100% (OE setting) to 110%.
    HTH
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
    Aug 2012
    London
    35
    Oh awesome, I'll have to check this the next time I fuel up! Can't wait for my cable to arrive :D
    2005 Audi A3 2.0 FSI Sport Sportback in Grey
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,870
    Quote Originally Posted by Gizmo68 View Post
    HTH
    Thanks Gizmo, That helps a lot.
  1. A2 Fuel Consumption - averages
    By Geckz in forum A2 forum
    Last Post: 2nd August 2009, 12:54
  2. Fuel consumption of 2.0FSi and 2.0T
    By A4_2point4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th February 2005, 09:57
  3. specific fuel consumption
    By ajmackie in forum General Technical / How To
    Last Post: 15th November 2004, 08:23
  4. Fuel Consumption on 3.2Q
    By MateloT in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2004, 07:21
