Audi Q7 battery dies what do these fault codes mean?
vw754
vorsprung Durch Technik
U.K
If i start and drive the car lets say at 12pm and i leave it sitting for a good12-14 hrs the car will just about turn over and start, on tuesday i parked the car up and today(thursday morning) battery was flat...i had to get out the jump leads to start it.
Audi fitted a brandnew battery end of dec 2011
I hooked up vcds and deleated previous faults,then did a full scan..........this is what i got
part no: 4F0 910 177
: 1 fault found 01699-motor for central locking hatch/trunk (v53)
009- open or short to ground
freeze frame fault status 01101001
fault priority 3
fault frquency 254
reset counter 137
time indication 0
date 2010 12 15
time 16:18:53
1 fault found:
02244-BUTTON ON CONTROL HEAD STUCK (this cleared when i messed with the sat-nav button)
03073 rear lid closed sensor 1
008 implausible signal-intermittent
priority 5.
2 faults found
02256 quiescent current
001-upper limit exceeded-intermittent
priority 7.
03041 energy management active
000----intermittent
priority 7
nice one,my cars a 56 plate....will audi have to do that?
No I did mine at home... I used a battery charger on the slave points under bonnet...
If you have bluetooth run disc 2 twice, so you would be doing disc 1 once, disc 2 twice, disc 3 once...
If you do not have bluetooth you would be doing disc 1 once, disc 3 once...
People have done it with the engine running but I'm not a fan of that as when flashing you really don't want voltage variance,etc...
Empty CD changer use slot one... the MMI FW update will only update what needs to be updated... ref the screenshots in the PDF above...
2G MMI HIGH v5570 update disk part no 4L0 998 961 is available on ebay but IIRC Audi dealer is cheaper (less than a £10)...
They can get iffy about supply but will sell them to you... MMI update can take upto an hour...
Early hardware versions of bluetooth modules can sometimes not like a flash update but other modules in your car may not as well...
Flashing is not risk free...
make your own mind up and do what you wish...
Use google and search for mmi flashing failure or mmi update issue ... etc etc etc ...
Plenty info on web... try to use as least amount of electrical items in car when flashing, use a charger...
Switched off AC/blower... switch off interior lights, any "Auto" functions like coming/leaving home lights, etc,etc...
On my A6 I did lose "Battery Meter" & "Instrument Cluster" menus in "Car" menu but by VCDS you can re-enable those...
The MMI update does all MMI related modules (Radio unit, AMP, etc) ...
i dare not try that.......too technical for me,and if it goes wrong im done!
Just a thort,is it good to get my battery tested by car spares/auto shop.......audi fitted a new one in may 2011 and if im right all audi parts carry a 2 year warranty?..........maybe its just a battery issue?
You can do measuring blocks in the battery regulation module...
Link:- Audi Portal: ECU Diagnostic . Audi Q7 4L (2007- ) . Energy Manager J644
SOC (State of charge) is a good one top look at...
With the MVB's in above you can also see if the alternator is functioning correctly on charging,etc...
Yes genuine Audi parts have 2 yrs warranty... with VAS they can see even more battery data/history than what VCDS can...
For MMI update they may charge an hours labour... highlight the TPI/TSB then they will do it without diags charge possibly...
I've seen posts where they replace the battery first then when customer still has issue then they do MMI update...
One guy had an alternator changed, then battery then finally they did MMI update as neither the first two bits of work fix issue...
They did the update for free after they had charged for the alternator & battery...
They did the update for free after they had charged for the alternator & battery...[/
Dont know if ive done these right,id just started the car and it was at idle.........when i switched the car off
and with ignition on only the battery voltage started drop to 1185 but as i didnt want accidently kill the battery,i unplugged vcds.
The first picture is when car was off and only ignition was on.
http://i851.photobucket.com/albums/ab80/vw754/DSC_0593_zpsea581c98.jpg
http://i851.photobucket.com/albums/ab80/vw754/DSC_0592_zps945929d3.jpg
http://i851.photobucket.com/albums/ab80/vw754/DSC_0591_zpsa9124a45.jpg
http://i851.photobucket.com/albums/ab80/vw754/DSC_0590_zps0a289808.jpg
In one of your photos SOC=80% so I would say battery is fine...
You can press "PRT SC" on keyboard and then open paint and paste a screenshot and then edit/upload...
I've recently been using this Link:- FastStone Screen Capture - The Best Screen Capture Software
This allows you to capture screen, files are great sizes for uploading to youtube and you get no screen glare,etc,etc :) ...
after parked up for 16 hours,this morning started fine.
I had a new battery,coded it and its been ok,checked with vcds today,cars been standing for around 74 hours and atate of charge is 60% battery condition is 90% is that normal?
battery management was activated ...i deleted all codes,now all codes have dissapeared
Hopefully thats sorted it out for you.
I had a new battery,coded it and its been ok,checked with vcds today,cars been standing for around 74 hours and state of charge is 60% battery condition is 90% is that normal?
SOC so should not be 60% IMO ... battery condition in the MMI is =
Battery condition
The battery condition indicates how efficient the battery is. The efficiency is determined from the battery charge level and the ability to start.
Its not a volts/amps meter...
SOC =
Knowing the amount of energy left in a battery compared with the energy it had when it was full gives the user an indication of how much longer a battery will continue to perform before it needs recharging. Using the analogy of a fuel tank in a car, State of Charge (SOC) estimation is often called the "Gas Gauge" or "Fuel Gauge" function.
The SOC is defined as the available capacity expressed as a percentage of some reference, sometimes its rated capacity but more likely its current (i.e. at the latest charge-discharge cycle) capacity but this ambiguity can lead to confusion and errors. It is not usually an absolute measure in Coulombs, kWh or Ah of the energy left in the battery which would be less confusing.
I had a new battery in Jan 13 ... I do very little miles a day... have plenty of toys in my car... my SOC is 80%+ depending on being stood for several days or none...
Place a multimeter on battery lock car and see if you have a parasitic draw...
SOC =
Place a multimeter on battery lock car and see if you have a parasitic draw.il see if you can help 1 more time,i drove car to work on a 22 mile run
there and back,then scanned it,these are results.....battery state of charge
was 80% battery condition 100%
drove the car to work today,a stright road to work with a few stop/traffic,and 11 miles each way,i checked state of charge and it was 80% and battery condition was 100%........then i did a full scan and here are the results (tried to clear them they pop right back up)
Tuesday,19,March,2013,15:16:25:07342
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
55 56 61 62 67 6D 6F 72 76 77
VIN: WAUZZZ4L07D034266 Mileage: 139020km/86383miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4L0 910 401 M HW: 4L0 907 401
Component: 3.0L V6TDI G000AG 0030
Revision: --H05--- Serial number:
Coding: 0011775
Shop #: WSC 06144 000 1048576
VCID: 2C5C11CB8F179978AD4
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FK HW: 09D 927 750 FK
Component: AL 750 6A 0940
Revision: 00H52000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 7CFCE18B3FF7C9F87D4
Address 03: ABS Brakes Labels: 4L0-910-517.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H21001
Coding: 0038033
VCID: 2854EDDB9BEFB55849C
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601000493662
Coding: 0000147
Shop #: WSC 00202 210 80978
VCID: E3CE3AF722499600DCE
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 731 K HW: 4E0 035 729
Component: Interfacebox H43 4220
Revision: 00000000 Serial number: 386GZ067515771
Coding: 0002002
VCID: 306405BBA33FFD9891C
Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000000153176
Coding: 0298006
Shop #: WSC 00202 210 50776
VCID: E1C230FF38558410CE2
2 Faults Found:
00565 - Rear A/C Control Head (Climatronic) (E265)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 139024 km
Time Indication: 0
Date: 2013.03.19
Time: 15:10:01
Freeze Frame:
ON
01207 - Control Module for Auxiliary Heater (J364)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 139024 km
Time Indication: 0
Date: 2013.03.19
Time: 15:10:01
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0013121
VCID: 316200BFA835F4909E2
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0100
Coding: 00022806
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 111 A HW: 4L0 035 111
Component: CD-Changer H41 0100
Revision: 00000000 Serial number: AUZ5ZBF3031364
Shop #: WSC 00000 000 00000
VCID: 1E38CB03C9AB7BE8330
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 B HW: 4L0 959 655
Component: 31 AIRBAG AUDI8RH38 0120
Revision: 05H38000 Serial number: 0037GD06EATC
Coding: 0013105
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90054061900297
Coding: 0102142
VCID: E6C823E3D17BE3283B0
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 G
Component: KOMBIINSTR. M73 H17 0110
Revision: 00300000 Serial number: 5HJ38KC76
Coding: 2657443
VCID: 234EFAF7E2C956001CE
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 C
Component: Heizgeraet H07 0060
Revision: 0000000E Serial number: 00000009011043
Coding: 0000002
VCID: E0C435FB335F8D18C1C
1 Fault Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B067198014
Coding: F55BBE7F307202
VCID: ECDC51CBCF97D9786D4
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 B HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7550
Revision: --H03001 Serial number: 15.1528-0095.2
Coding: 0015510
VCID: 2952E8DF80E58C50562
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H48 0850
Revision: 00000000 Serial number: 399GY067530247
VCID: 3B7E22977A790EC034E
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: gh,
Coding: 0002651
VCID: 2F6606C7BE01E260886
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01016072060000
Coding: 7348475
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
1 Fault Found:
01699 - Motor for Central Locking; Hatch/Trunk (V53)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 16
Reset counter: 189
Mileage: 138952 km
Time Indication: 0
Date: 2013.03.14
Time: 18:08:08
Address 47: Sound System Labels: Redir Fail!
Part No SW: 4L0 910 223 B HW: 4L0 035 223
Component: DSP-AU716 H20 0100
Revision: 11S00001 Serial number: 01307060320074
Coding: 0000013
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000004784
Coding: 0011101
VCID: DEB80B03092BBBE8F30
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: uf
Coding: 0002651
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000022
Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388GW067540507
Coding: 0000001
VCID: 2E581BC3B90BEB68830
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000029522
Shop #: WSC 00551 210 86264
VCID: E4CC39EB27479138254
Subsystem 1 - Part No: 009 2S5 013 0
Component: von VA0 536079390A
Coding: 303039325335303133302056413035333630373933393041
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 229
Mileage: 138989 km
Time Indication: 0
Date: 2013.03.19
Time: 00:49:35
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0002058
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000607050343
Shop #: WSC 12336 024 394758
VCID: 366833A3415BD3A8CB0
Address 6D: Trunk Elect.
Cannot be reached
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 001845617-----
Coding: 0000001
VCID: E5CA24EF2C7DE83032A
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist
Cannot be reached
Address 77: Telephone
Cannot be reached
End ..
I drove the car to work today,a stright road to work with a few stop/traffic,and 11 miles each way,i checked state of charge and it was 80% and battery condition was 100%........then i did a full scan and here are the results (tried to clear them they pop right back up)
i wonder sometimes....if what i read has some truth?.............MMI upgrade? if that could help?
Your MMI version is 4220
I did a quick google of fault code from below section...
1 Fault Found:
Most info seems to suggest a drain occurring...
You also have a AUX Heater... IIRC I've read some info within some A8 posts relating to draining with this, will dig it up...
Get a multimeter on battery and monitor if drain happening after locking car up... parasitic draw ...
thanks mate,i dont know how use multimeter,but if it is pointing to drainage,id really appreciate it if you would dig up the cause,thanks.
how do these aux heaters work? also in 61-battery regulation, in measure blocks group 007 ive got this if it means anything
ch1..... 0-19.......ch2.(count) 1 ...... ch3........Not ok...........ch4.......ok
Ive updated the mmi using 3 genuine audi cd's ,replaced battery and coded it,first few days (7 days) battery is still fully charged now after a couple of months sometimes it will still be fully charged after 4 or 5 days,i could go and check now and it could be fully charged(thats after the cars been sitting for 4 days) i could go to it tomorrow and it will show only 10% charge. i get a fault 01699 tailgate lock/hatch could this drain it?
it works ok just get the flickering when the tailgate opens.
Have i missed something? do i need to get rid of battery history or something?
Hi :-}
firsy check the quiescent current consumption
http://uberlame.com/a6_tsb/Electrical/Battery Dead (2).pdf
check number in bluetooth ecu{software SW and HW}
the Audi Q7 were mostly damaged bluetooth modules.
Make sure that your car does not require a service action to change the software to tailgate.
"do i need to get rid of battery history or something?" YES
I did use current clamps 50 amper {importent} and VAS 5052b .Maximum
quiescent current consumption is 50 MiliAmper !!
You have to close the car and wait about 10 minutes.
Easier way is to read the history of the battery{vas5052b }
or use VCDS and see in these values
yes
Maximum static current is 50 miliamper!
i get a fault 01699 tailgate lock/hatch could this drain it?"
yes
First step -check your car for
recall -tailgate software update.
il do that and get back to you thanks
yes
yes
is there a number i can call you on,if you have 5 minutes at some point to talk me through it????????
if not il try do the 'audi portal' thing
yes
yes
DONT UNDERSTAND THIS: I did use current clamps 50 amper {importent} and VAS 5052b .Maximum quiescent current consumption is 50 MiliAmper !!
On the A6 there is a recall (TSB/TPI) on power tailgate ... will have a nose if one exist/applicable to Q7 ...
So you still have this error...
Coding: 7348475
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 189
Mileage: 138952 km
Time Indication: 0
Date: 2013.03.14
Time: 18:08:08
JUST DONE THIS ABOUT 30 MINS AGO: VCDS Version: Release 11.11.5
Sunday,12,May,2013,21:36:14:07342
Chassis Type: 4L0
VIN: WAUZZZ4L07D034266 Mileage: 140010km/86998miles
09-Cent. Elect. -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Coding: 0011775
Coding: 0000504
Revision: 00H21001
Coding: 0038033
Coding: 0000147
Part No SW: 4L1 910 732 G HW: 4E0 035 729
Component: Interfacebox H43 5570
Coding: 0002002
Coding: 0298006
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 139997 km
Time Indication: 0
Date: 2013.05.10
Time: 17:10:50
Freeze Frame:
ON
Coding: 0013121
Coding: 00022806
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 27
Mileage: 139996 km
Time Indication: 0
Date: 2013.05.10
Time: 17:10:00
02746 - Bulb for Daytime Running Light; Right
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 140008 km
Time Indication: 0
Date: 2013.05.12
Time: 21:08:00
Coding: 0013105
Coding: 0102142
Coding: 2657443
Coding: 0000002
Coding: 0015510
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 67
Mileage: 140011 km
Time Indication: 0
Date: 2013.05.12
Time: 21:08:52
Freeze Frame:
Error Code: 13
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: gh‚
Coding: 0002651
Coding: 7348475
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 109
Reset counter: 25
Mileage: 139057 km
Time Indication: 0
Date: 2013.03.26
Time: 11:22:20
Coding: 0000013
Coding: 0011101
Revision: 00000000 Serial number: uƒ
Coding: 0002651
Coding: 0000022
Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0630
Coding: 0000001
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 67
Mileage: 140002 km
Time Indication: 0
Date: 2013.05.11
Time: 00:57:10
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Mileage: 140011 km
Time Indication: 0
Date: 2013.05.12
Time: 21:04:59
Coding: 0002058
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 A
Component: ValeoHeckdeckel H20 0280
Revision: --H20001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Part No: 4L0 910 946
Coding: 0000001
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0002058
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06320618801916
Coding: 0201146
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000000000000
Coding: 0010900
URL=http://s851.photobucket.com/user/vw754/media/P3_zps0b7ffb31.jpg.html]
URL]
[/URL]
"DONT UNDERSTAND THIS: I did use current clamps 50 amper {importent} and VAS 5052b .Maximum quiescent current consumption is 50 MiliAmper !!
You have to close the car and wait about 10 minutes."
Sorry :-}
when you close the key remote control car, a few minutes later, when all the ECU are sleeping, quiescent current must not be more than 50 mili-amper.
Each power consumption over 50 miliamper will cause discharge of the battery.
check the battery history, the best vas 5052b.
Example of TSB
t
2006-09-20,22:18:46*0012 hours 00.71 A, quiescent current
2006-09-19,16:37:06*0018 hours 00.70 A, quiescent current
2006-09-19,13:08:12*0000 hours 00.70 A, quiescent current
2006-09-18,17:23:16*0015 hours 00.70 A, quiescent current
2006-09-17,20:53:45*0012 hours 00.71 A, quiescent current
2006-09-17,17:20:20*0001 hours 00.70 A, quiescent current
2006-09-16,22:05:17*0017 hours 00.70 A, quiescent current
2006-09-16,19:47:44*0000 hours 00.70 A, quiescent current
quiescent current over 50 miliamper , 00.70 a in this case, the battery will be discharged
correct current consumption should be max 00.50A ={ 50 miliamper}
i have only vcds (vag-com) so cannot check anything else,ive posted some pics regarding the audi portal,if you need more info let me know.
Sorry :-}
Ive been told ive done all the main things....ive updated mmi.......updated the nav disc,put in new battery and coded it.
Some say the auxilary heater drains the battery?...........any ideas where and which the fuse is so i can pull the fuse see if that stops battery draining.........unless you have any ideas?
Go into VCDS, press Applications, press Erase All DTCs.
Do a few ignition cycles and rescan.
