Page 2 of 2 FirstFirst 12
Results 41 to 57 of 57
  1. #41
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,851
    done exactly as you said ,battery state of charge is 60% battery condition is 100% only as ive driven the car to work and back (30 min there and 30 mins back) HERES THE SCAN AFTER I CLEARED THE DTCS AS YOU SAID :
    Chassis Type: 4L0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
    55 56 61 62 67 6D 6F 72 76 77
    VIN: WAUZZZ4L07D034266 Mileage: 140040km/87016miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    6F-Centr. Conv. II -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4L0 910 401 M HW: 4L0 907 401
    Component: 3.0L V6TDI G000AG 0030
    Revision: --H05--- Serial number:
    Coding: 0011775
    Shop #: WSC 06144 000 1048576
    VCID: 2C5C11CB8F179978AD4
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09D-927-750.lbl
    Part No SW: 09D 927 750 FK HW: 09D 927 750 FK
    Component: AL 750 6A 0940
    Revision: 00H52000 Serial number:
    Coding: 0000504
    Shop #: WSC 31414 790 00001
    VCID: 7CFCE18B3FF7C9F87D4
    Address 03: ABS Brakes Labels: 4L0-910-517.clb
    Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
    Component: ESP ALLRAD MK25E1 0130
    Revision: 00H21001
    Coding: 0038033
    VCID: 2854EDDB9BEFB55849C
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000493662
    Coding: 0000147
    Shop #: WSC 00202 210 80978
    VCID: E3CE3AF722499600DCE
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
    Part No SW: 4L1 910 732 G HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 386GZ067515771
    Coding: 0002002
    VCID: 2E581BC3B90BEB68830
    Part No: 4L0 910 609
    Component: E0380 BedienteilH01 0060
    Address 08: Auto HVAC Labels: None
    Part No SW: 4L0 910 043 HW: 4L0 820 043 F
    Component: KLIMABETAETIGUNGH05 0060
    Revision: 00---012 Serial number: 00000000153176
    Coding: 0298006
    Shop #: WSC 00202 210 50776
    VCID: E1C230FF38558410CE2
    1 Fault Found:
    00565 - Rear A/C Control Head (Climatronic) (E265)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 140045 km
    Time Indication: 0
    Date: 2013.05.13
    Time: 20:21:07
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    VCID: 316200BFA835F4909E2
    Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AU716 H12 0100
    Coding: 00022806
    Shop #: WSC 31414
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150059
    Shop #: WSC 31414
    1 Fault Found:
    02745 - Bulb for Daytime Running Light; Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 140008 km
    Time Indication: 0
    Date: 2013.05.13
    Time: 12:30:00
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4L0 910 111 A HW: 4L0 035 111
    Component: CD-Changer H41 0100
    Revision: 00000000 Serial number: AUZ5ZBF3031364
    Shop #: WSC 00000 000 00000
    VCID: 1E38CB03C9AB7BE8330
    Address 15: Airbags Labels: 4L0-910-655.lbl
    Part No SW: 4L0 910 655 B HW: 4L0 959 655
    Component: 31 AIRBAG AUDI8RH38 0120
    Revision: 05H38000 Serial number: 0037GD06EATC
    Coding: 0013105
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H08 0230
    Revision: 00H08000 Serial number: 90054061900297
    Coding: 0102142
    VCID: E6C823E3D17BE3283B0
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4L0 920 980 G
    Component: KOMBIINSTR. M73 H17 0110
    Revision: 00300000 Serial number: 5HJ38KC76
    Coding: 2657443
    VCID: 234EFAF7E2C956001CE
    Address 18: Aux. Heat Labels: None
    Part No SW: 4L0 910 105 HW: 4L0 815 071 C
    Component: Heizgeraet H07 0060
    Revision: 0000000E Serial number: 00000009011043
    Coding: 0000002
    VCID: E0C435FB335F8D18C1C
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 HW: 4L0 907 468
    Component: J533__Gateway H06 0040
    Revision: 00H06000 Serial number: 0900B067198014
    Coding: F55BBE7F307202
    VCID: ECDC51CBCF97D9786D4
    Address 34: Level Control Labels: None
    Part No SW: 4L0 910 553 B HW: 4L0 907 553
    Component: LUFTFDR.-CDC H03 7550
    Revision: --H03001 Serial number: 15.1528-0095.2
    Coding: 0015510
    VCID: 2952E8DF80E58C50562
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H48 1060
    Revision: 00000000 Serial number: 399GY067530247
    VCID: 3B7E22977A790EC034E
    Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
    Component: TSG FA H12 0130
    Revision: 00000000 Serial number: gh‚
    Coding: 0002651
    VCID: 2F6606C7BE01E260886
    Address 46: Central Conv. Labels: 4L0-910-289.lbl
    Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
    Component: Komfortgeraet H05 0020
    Revision: 0020 --- Serial number: 01016072060000
    Coding: 7348475
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 109
    Reset counter: 25
    Mileage: 139057 km
    Time Indication: 0
    Date: 2013.03.26
    Time: 11:22:20
    Address 47: Sound System Labels: Redir Fail!
    Part No SW: 4L0 910 223 B HW: 4L0 035 223
    Component: DSP-AU716 H20 0100
    Revision: 11S00001 Serial number: 01307060320074
    Coding: 0000013
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 E
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000004784
    Coding: 0011101
    VCID: DEB80B03092BBBE8F30
    Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
    Component: TSG BF H12 0130
    Revision: 00000000 Serial number: uƒ
    Coding: 0002651
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000022
    Part No: 7L6 941 329 A
    Component: AFS-Modul links H06 0002
    Component: AFS-Modul rechtsH06 0002
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 388GW067540507
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4L0 910 181 HW: 4L0 915 181
    Component: J0644 BEM H12 0530
    Revision: -------- Serial number: 00000000029522
    Shop #: WSC 00551 210 86264
    VCID: E4CC39EB27479138254
    Subsystem 1 - Part No: 009 2S5 013 0
    Component: von VA0 536079390A
    Coding: 303039325335303133302056413035333630373933393041
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 69
    Mileage: 140045 km
    Time Indication: 0
    Date: 2013.05.13
    Time: 20:21:02
    Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
    Component: TSG HL H21 0050
    Coding: 0002058
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
    Component: SDS 3502 UK H45 0630
    Revision: 00000000 Serial number: 00000607050343
    Shop #: WSC 12336 024 394758
    VCID: 366833A3415BD3A8CB0
    Address 6D: Trunk Elect. Labels: None
    Part No SW: 4L0 910 945 HW: 4L0 827 851 A
    Component: ValeoHeckdeckel H20 0280
    Revision: --H20001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    Part No: 4L0 910 946
    Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
    Part No SW: 4L0 910 290 HW: 4L0 907 290
    Component: ILM HINTEN 2 H05 0060
    Revision: AAH05061 Serial number: 001845617-----
    Coding: 0000001
    VCID: E5CA24EF2C7DE83032A
    Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
    Component: TSG HR H21 0050
    Coding: 0002058
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
    Component: Parkhilfe 8-Kan H12 0060
    Revision: 00H12000 Serial number: 06320618801916
    Coding: 0201146
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H13 1130
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0010900
    Quote Originally Posted by a6-chris View Post
    Go into VCDS, press Applications, press Erase All DTCs.
    Do a few ignition cycles and rescan.
    Full leather/19"wheels/cruise/
  3. #42
    May 2013
    60
    "01699 - Motor for Central Locking; Hatch/Trunk (V53)
    009 - Open or Short to Ground"
    I think that 46 - ECU convienience not sleep after closing the car, because of your tailgate is not closed properly.
  4. #43
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    My tailgate closes properly,and i dont get any lights on in the boot area,and i dont get any lights on in the dash panel stating tailgate is open.
    Also is this the lock/latch in the actual tailgate or the one inside the aluminium trim panel above the rear bumper?
    Would i not get any lights on boot/dash if tailgate was not closed,or what do i need to do here to fix this problem ?
    Quote Originally Posted by christof71 View Post
  5. #44
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    259
    V53 is the one in the chassis, below the alu.trim ... P/N is 8P4 827 505 C APPROX. £35 @ dealer ...
    Even though you have done DTC clear in VCDS the fault has old date ...
    1 Fault Found:
    Date: 2013.03.26
    Time: 11:22:20
    Try going into module 46 on its own, then clear fault directly in module ... cycle ignition on/off and open/close tailgate and scan again ...
    On the A6 the Hazard switch stays illuminated after locking to indicate car has not entered sleep mode, once in sleep mode (after a few minutes) the illumination will switch off ... does the Q7 do this?
    Try connecting a multimeter directly to battery and placing multimeter at a position you can view it through a window once car is locked ... Link:- How To Perform a Parasitic Draw Test
    It looks like you can check no-load voltage on the slave charge points in the engine bay but you can't use them for the amps parastic draw test there...
    PM an external email for some stuff that may help you ...
  6. #45
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    Il try to clear the fault but it come back instantly,il give it another try tomorrow,my tailgate flickers every time it starts to open,it flickers about 4-5 times before opening quietly.I have taken the latch off cleaned it and used penetrating spray on it,but it seemed to be working ok.........maybe they still work when they get faulty...who knows........IL check the hazard switch but when i do lock the car nothings lit up in there when ive peered through the window,thanks for the help,ive seny you a pm with my number if your in the uk,and my e-mail.
    Quote Originally Posted by gupsterg View Post
  7. #46
    May 2012
    RETFORD, NOTTS
    1,707
    Auxiliary heater can be set with a timer, is this coming on early in the morning without you knowing? It warms up the cabin heater. Without the engine running.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  8. #47
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    turned off via mmi.not cold enuf here for it to come on i dont think anyway
    Quote Originally Posted by @udi A3 View Post
  9. #48
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    this pic shows the lock on the tailgate?
    Quote Originally Posted by vw754 View Post
  10. #49
    May 2012
    RETFORD, NOTTS
    1,707
    On my car the alarm doesn't set if the door latches are not closed. Also there is possibly measuring blocks in vcds to check the switches state
  11. #50
    May 2013
    60
    I do not have 100 percent certainty, but I began to look for a problem where I get an faults.
    If you can ,verify the continuity of the wiring harness between the 46 ECU and the engine V53
    give me your engine code and year of the car, I'll give you the pin numbers of the plug controller 46 and V53
    "Would i not get any lights on boot/dash if tailgate was not closed,or what do i need to do here to fix this problem ?"
    I'm not sure, but I saw in the lock tailgate 2 microswitches and electric motor V53
  12. #51
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    2006 'BUG'
  13. #52
    gupsterg's Avatar
    Jun 2012
    259
    @ vw754 ...
    Via PM you have info on "No load" testing , "Parastic Draw" testing ...
    Check your email inbox as I have sent you full fuses list as well, PDF's on slave points & VAG "No load" & "Current Draw" docs ...
    Before buying any parts diagnosis the current drain/draw ...
    ATB
    G
  14. #53
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    ok,nice one will get back to you.
    @ vw754 ...
    ATB
    G
  15. #54
    May 2013
    60
    Convenience system central control unit pin T10g/ 1 = V53 motor Pin 4
    T32d/22 = V53 motor pin 1
    v53 pin 3 =ground
    v53 pin 2 = Rear lid control unit 2 pin 3
    T32d - 32-pin connector, on convenience system central control unit
    T10g - 10-pin connector, black, on convenience system central control
  16. #55
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    got it done at my mates place (vagtronics) when car was asleep the reading on the multimeter was 0.20/0.21 M-amps fluctuating finaly pulled out the fuse that had the roofmounted tv connected to it and when car was locked the reading dropped to 0.05/0.06 M- amps fluctuating so hopefully that reading is ok?
  17. #56
    May 2013
    60
    0,05 / 0,06 = 50 miliamper OK
    0.20/0.21 = 200 /210 miliamper .not/ok
    So you find the problem.:-}
    I forgot to tell you that you first need to disconnect all electrical Upgrade of Equipment which is not the original
    I wish you a nice weekend:-}
  18. #57
    vw754's Avatar
    Nov 2006
    U.K
    1,851
    THANKYOU
  1. What do these fault codes mean ?
    By JeePee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2011, 22:40
  2. What do my fault codes mean!?
    By Tobiasnugent in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2011, 10:29
  3. What do these DTC codes mean??
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th February 2011, 08:58
  4. Can anyone tell me what these fault codes are please?
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2006, 13:16
  5. Can anyone decode these fault codes?
    By cha1n in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2006, 11:22
