ricostuart
Yesterday the car decided to start misfiring on me. It felt like only 1 of the cylinders as it wasnt too severe. Thankfully only had a short distance to get home. The CEL only started flashing just as i pulled into my parking space. I bought a VCDS cable which arrived today (yay for amazon!). Could anyone please have a look through the codes and tell me whats needing replaced?
I know my rear parking sensors are faulty (dont know what yet, but all 4 dont vibrate - the fronts work fine), and the missfiring. I have now cleared all faults too.
Thanks.
Thanks.
Code:
Tuesday,19,February,2013,11:35:40:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E45A484660 Mileage: 136880km/85053miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E0 910 560 L HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: -------- Serial number:
Coding: 0011771
Shop #: WSC 06335 000 00000
VCID: 2E591061B90C649
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
16685 - Cylinder 1
P0301 - 001 - Misfire Detected - Intermittent
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E0 910 156 M HW: 09L 927 156
Component: AG6 09L 4.2L5V RdW 0040
Revision: --H01--- Serial number: 0087083
Coding: 0000001
VCID: 30650E19A338729
No fault code found.
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004902
VCID: 2757E54596F6351
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 6
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x00FF
Hex Value: 0xFF92
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6CDDDA691C90D69
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul ECE 0303
Coding: 01021
Shop #: WSC 06335
VCID: 3973333D2342B31
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
49-10 - No Communications - Intermittent
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M002A76D
Coding: 0033722
VCID: 3B7F29357A7E811
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenks·ulenmodul 0601
Coding: 04141
Shop #: WSC 06335
VCID: 41835BDD4B92EB1
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 P HW: 8E0 920 981 P
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0007441
Shop #: WSC 21438 210 72067
VCID: 3A712C317644B89
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H53 0650
Revision: 08S Serial number: AUZBZ7D0405753
Coding: 0301217
Shop #: WSC 00836 210 61229
VCID: 244DF249E4C0DE9
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 14
Reset counter: 15
Time Indication: 0
Date: 2013.02.01
Time: 17:45:55
Freeze Frame:
Mileage: 655350 km
Count: 802
Clock: 09:24
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
VCID: EBDF5975999E511
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BM
Component: Komfortger·t T3B 2431
Coding: 06907
Shop #: WSC 06335
VCID: 7DFBE72D77EA4F1
Subsystem 1 - Part No: 8E2959802B
Component: Tırsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E2959801B
Component: Tırsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tırsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tırsteuer.HR BRM 0205
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00956 - Key 2
35-10 - - - Intermittent
00532 - Supply Voltage B+
37-10 - Faulty - Intermittent
01331 - Door Control Module; Driver Side (J386)
80-10 - Single-Wire Operation - Intermittent
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 B
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 3973333D7042B31
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301217
1 Fault Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 14
Reset counter: 15
Time Indication: 0
Date: 2013.02.01
Time: 17:45:55
Freeze Frame:
Mileage: 655350 km
Count: 802
Clock: 09:24
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 C HW: 8E0 919 283 C
Component: Parkhilfe 8-Kan H06 0020
Revision: 00H06000 Serial number: 00067802130435
Coding: 0001104
VCID: 30650E19A038729
5 Faults Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 31
Reset counter: 81
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
01548 - Sensor for Parking Aid; Rear Right (G206)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 22
Reset counter: 211
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 3
Reset counter: 41
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 90
Reset counter: 169
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 41
Reset counter: 248
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 D HW: 8P0 862 335 D
Component: FSE_255x BT H18 0050
Revision: 00000001 Serial number: 00000000177179
Coding: 0001822
VCID: 377735054556A51
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 37: DTCs cleared
Address 45: DTCs cleared
Address 46: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 76: DTCs cleared
Address 77: DTCs cleared
