Badger5Chris Nott
    Feb 2013
    Wiltshire
    345
    Unhappy 2007 B7 S4 Error codes and problem
    Yesterday the car decided to start misfiring on me. It felt like only 1 of the cylinders as it wasnt too severe. Thankfully only had a short distance to get home. The CEL only started flashing just as i pulled into my parking space. I bought a VCDS cable which arrived today (yay for amazon!). Could anyone please have a look through the codes and tell me whats needing replaced?
    I know my rear parking sensors are faulty (dont know what yet, but all 4 dont vibrate - the fronts work fine), and the missfiring. I have now cleared all faults too.
    Thanks.
    Code:
    Tuesday,19,February,2013,11:35:40:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
              69 75 76 77
    VIN: WAUZZZ8E45A484660   Mileage: 136880km/85053miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8E0 910 560 L    HW: 4E0 907 560
       Component: 4.2L V8/5V      G   0010
       Revision: --------    Serial number:
       Coding: 0011771
       Shop #: WSC 06335 000 00000
       VCID: 2E591061B90C649
    3 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
                P0300 - 001 -  - Intermittent
    16685 - Cylinder 1
                P0301 - 001 - Misfire Detected - Intermittent
    18010 - Power Supply Terminal 30
                P1602 - 002 - Voltage too Low - Intermittent
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 09L-927-760.lbl
       Part No SW: 8E0 910 156 M    HW: 09L 927 156
       Component: AG6 09L  4.2L5V RdW 0040
       Revision: --H01---    Serial number:        0087083
       Coding: 0000001
       VCID: 30650E19A338729
    No fault code found.
    Address 03: ABS Brakes        Labels: 8E0-910-517.lbl
       Part No SW: 8E0 910 517 C    HW: 8E0 614 517 BB
       Component: ESP8 quattro    H04 0180
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0004902
       VCID: 2757E54596F6351
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 3
                        Fault Frequency: 6
                        Reset counter: 40
                        Time Indication: 0
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x00FF
                        Hex Value: 0xFF92
                        Hex Value: 0x00FF
    Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
       Part No: 8E0 820 043 AM
       Component:   A4 Klimaautomat   2731
       Coding: 00000
       Shop #: WSC 00000
       VCID: 6CDDDA691C90D69
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 J
       Component: int. Lastmodul  ECE 0303
       Coding: 01021
       Shop #: WSC 06335
       VCID: 3973333D2342B31
    1 Fault Found:
    01326 - Control Module for Multi-Function Steering Wheel (J453)
                49-10 - No Communications - Intermittent
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H10 3230
       Revision: 91H10323    Serial number: 0036M002A76D
       Coding: 0033722
       VCID: 3B7F29357A7E811
    Address 16: Steering wheel        Labels: 8E0-953-549.lbl
       Part No: 8E0 953 549 Q
       Component: Lenks·ulenmodul     0601
       Coding: 04141
       Shop #: WSC 06335
       VCID: 41835BDD4B92EB1
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 981 P    HW: 8E0 920 981 P
       Component: KOMBI+WFS 4     H12 0040
       Revision: 0040        Serial number: 00000000000000
       Coding: 0007441
       Shop #: WSC 21438 210 72067
       VCID: 3A712C317644B89
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
       Part No SW: 8E0 035 192 C    HW: 8E0 035 192 C
       Component: RNS-E HIGH EU   H53 0650
       Revision:      08S    Serial number: AUZBZ7D0405753
       Coding: 0301217
       Shop #: WSC 00836 210 61229
       VCID: 244DF249E4C0DE9
    1 Fault Found:
    02261 - Data Medium
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 5
                        Fault Frequency: 14
                        Reset counter: 15
                        Time Indication: 0
                        Date: 2013.02.01
                        Time: 17:45:55
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 802
                        Clock: 09:24
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0804
       Coding: 00001
       Shop #: WSC 00000
       VCID: EBDF5975999E511
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8E0 959 433 BM
       Component: Komfortger·t T3B    2431
       Coding: 06907
       Shop #: WSC 06335
       VCID: 7DFBE72D77EA4F1
       Subsystem 1 - Part No: 8E2959802B
       Component: Tırsteuer.FS BRM 0205
       Subsystem 2 - Part No: 8E2959801B
       Component: Tırsteuer.BF BRM 0205
       Subsystem 3 - Part No: 8E0959801A
       Component: Tırsteuer.HL BRM 0205
       Subsystem 4 - Part No: 8E0959802A
       Component: Tırsteuer.HR BRM 0205
    6 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
                35-00 -  -
    00962 - Alarm via. Tilt Sensor
                35-00 -  -
    01368 - Alarm triggered by Luggage Compartment Switch
                35-00 -  -
    00956 - Key 2
                35-10 -  -  - Intermittent
    00532 - Supply Voltage B+
                37-10 - Faulty - Intermittent
    01331 - Door Control Module; Driver Side (J386)
                80-10 - Single-Wire Operation - Intermittent
    Address 55: Xenon Range        Labels: 8P0-907-357.lbl
       Part No: 8P0 907 357 B
       Component: Dynamische LWR  H01 0020
       Revision: 00000001    Serial number:
       Coding: 0000005
       VCID: 3973333D7042B31
    Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
       Coding: 0301217
    1 Fault Found:
    02261 - Data Medium
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 14
                        Reset counter: 15
                        Time Indication: 0
                        Date: 2013.02.01
                        Time: 17:45:55
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 802
                        Clock: 09:24
    Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
       Part No SW: 8E0 919 283 C    HW: 8E0 919 283 C
       Component: Parkhilfe 8-Kan H06 0020
       Revision: 00H06000    Serial number: 00067802130435
       Coding: 0001104
       VCID: 30650E19A038729
    5 Faults Found:
    01545 - Sensor for Parking Aid; Rear Left (G203)
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 3
                        Fault Frequency: 31
                        Reset counter: 81
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2000.01.01
                        Time: 00:00:00
    01548 - Sensor for Parking Aid; Rear Right (G206)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 22
                        Reset counter: 211
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2000.01.01
                        Time: 00:00:00
    00466 - Control Module for Steering Column Electronics (J527)
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 4
                        Fault Frequency: 3
                        Reset counter: 41
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2000.01.01
                        Time: 00:00:00
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 90
                        Reset counter: 169
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2000.01.01
                        Time: 00:00:00
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 41
                        Reset counter: 248
                        Mileage: 0 km
                        Time Indication: 0
                        Date: 2000.01.01
                        Time: 00:00:00
    Address 77: Telephone        Labels: 8P0-862-335.lbl
       Part No SW: 8P0 862 335 D    HW: 8P0 862 335 D
       Component: FSE_255x BT     H18 0050
       Revision: 00000001    Serial number: 00000000177179
       Coding: 0001822
       VCID: 377735054556A51
    End   ---------------------------------------------------------------------
    Address 01: DTCs cleared
    Address 02: DTCs cleared
    Address 03: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 15: DTCs cleared
    Address 16: DTCs cleared
    Address 17: DTCs cleared
    Address 37: DTCs cleared
    Address 45: DTCs cleared
    Address 46: DTCs cleared
    Address 55: DTCs cleared
    Address 56: DTCs cleared
    Address 76: DTCs cleared
    Address 77: DTCs cleared
    27,026
    Thats a fake non genuine illegal cable, the forum does not support the use of said items, I suggest you return it & ask for a full refund & buy a genuine version as it cant be updated, not warranted by RT, not entitled to support from RT.
  1. Error Code Problem On 2.0l TDI (P2101/P2100)
    By makavelli in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2014, 19:34
  2. White smoke - Too much oil and error code 004243
    By Nickl in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2012, 08:51
  3. Error codes p3105 and p19561
    By vinnyl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd October 2009, 12:23
  4. Help with error codes P1103, P0139 and P0411
    By royster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th September 2007, 22:12
  5. error code 00575, and sqealing noise
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 23:38
