DTM_Dan
Ok - very new to VCDS having opted to buy it.
I recently retro fitted a MFSW & Cruise control to my 55 A4 DTM. Good news is that the MFSW works great. However the Cruise control doesnt. I have two issues, 1) steering angle setup and 2) I cannot login to section 11 under 03 ABS brakes. it is ghosted out and says coding. I may have done something wrong here, i'm not sure. Also once i do get in to this login the DTM brake code is not listed when creating the login code.
As a result i have the ESP light on the dash - and i am guessing no ABS.
logs:
Saturday,16,February,2013,10:00:25:62907
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
Component: ESP8 quattro H05 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004526
Shop #: WSC 06335 000 00000
VCID: 2953CA32800C9950562
1 Fault Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 22
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x001E
Hex Value: 0x3E8F
Hex Value: 0x0001
Any help gratefully received. I have tried the process ofr re-calibraing the sensor - but with no success.
logs:
69 75 76 77
Coding: 0004526
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x001E
Hex Value: 0x3E8F
Hex Value: 0x0001
