Chris NottBadger5
    May 2012
    RETFORD, NOTTS
    1,753
    New fault after coding CC on a 2007 A4
    Just wondered if anyone has come across this? I emailed rosstech but its bugging me. Fault was not present before coding CC, and coding was sucessfull. This is the after log after a DTC reset and a drive.
    Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 JN HW: 03L 906 022 B
    Component: R4 2,0L EDC H01 3174
    Revision: 11H01---
    Coding: 010C002C02072118
    Shop #: WSC 06335 123 12345
    ASAM Dataset: EV_ECM20TDI03L906022JN A01004
    ROD: EV_ECM20TDI03L906022JN.rod
    VCID: 7AFB4C23FDCB18C86F8
    1 Fault Found:
    4332 - Check Coding of ECUs on Powertrain Data Bus
    P1647 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 133693 km
    Date: 2013.02.17
    Time: 20:00:23
    Readiness: 0 0 0 0 0
    The only other code present is
    Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
    Part No SW: 8K9 827 851 HW: 8K9 827 851
    Component: J605 Master H24 0240
    Revision: -------- Serial number: 8K9827851
    VCID: FBF5C9277AF1A1C0F4E
    Subsystem 1 - Part No SW: 8K9 827 852 HW: 8K9 827 852
    Component: J756 Slave H24 0240
    2 Faults Found:
    16347 - Control Module - EEPROM Error
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 57
    Mileage: 133693 km
    Time Indication: 0
    Date: 2013.02.17
    Time: 19:49:26
    02242 - Rear Lid Lock Button in Luggage Compartment (E406)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 57
    Mileage: 133693 km
    Time Indication: 0
    Date: 2013.02.17
    Time: 19:49:26
    Could they be linked? The 01 engine fault was not there before coding but the bootlid issue was.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    27,099
    This came up on an 07 A4, strange as one of the part numbers doesnt even fit the B7 A4, confirm the year & chassis type, maybe a B8 08?
    May 2012
    RETFORD, NOTTS
    1,753
    Sorry it was a b8.
    Rosstech suggested recoding gateway to same value again to see if fault resets.
    havent tried as yet.
  1. Vag Com Faults after Coming Home & Leaving Home Lights Enabled .
    By Digzz in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd February 2010, 14:45
  2. 9 faults found. Codes inside...Please help!!!
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2010, 15:12
  3. Faults after remap!
    By Jay4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th August 2007, 17:16
  4. My new S3 after a clean
    By nky_84 in forum Photography & The Digital Darkroom
    Last Post: 4th April 2007, 17:52
