Sky InsuranceChris Nott
Results 1 to 15 of 15
    Mar 2012
    Essex
    118
    Red face Pls help with 2 fault codes!
    I have had a scan done and the following 2 codes showed up.
    They appear to be fan related, although I've never seen the car go past halfway on the temp gauge. Any opinions on how to fix them are welcome...Cheers
    06471 - Control Module 2 for Cooling Fan
    P1947 - 001 - Over-Temp
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 39
    Mileage: 179933 km
    Time Indication: 0
    Freeze Frame:
    RPM: 798 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 13.8 %
    Duty Cycle: 13.8 %
    Duty Cycle: 13.8 %
    Duty Cycle: 13.8 %
    001683 - Fan 2 Control Circuit
    P0693 - 001 - Short to GND - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 68
    Mileage: 179933 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 9.9 %
    Voltage: 12.01 V
    27,038
    Show the full log please.
    Mar 2012
    Essex
    118
    Is there more then? I'll get back to him and ask for it all if there's more
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Re: Pls help with 2 fault codes!
    What's wrong with the two fault codes?
    They show the fault codes, the log won't show any more apart from part numbers and version number.
    Looks like a cabling fault.
    Have you checked the plug and cables?
    Do the fans work?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Mar 2012
    Essex
    118
    Thanks Scott. I'll look tomorrow (at the plug & cables), but are there 2 fans? I know for sure 1 of them is working as I can hear it now and again.
    BTW, I have a 3.0L V6 TDI
    27,038
    Well where do I start, well he hasnt given us any info about the car, what year, what chassis, what engine, what gearbox, etc etc, do I really need to go on???
    Some cars have known problems related to these codes, some dont, so to advise more precisely we need more info, thought that would be obvious tbh.
    Always provide a full log of the car if you're asking for help aswell as the car info.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    Car details is a must, true and he finally posted them.
    Any other faults with in the logs could be usefully but that single line on its own about posting more winds me up.
    It reads like your wanting segregate people if it's not a gen version, that might not be the case and just me reading more in to it.
    Mar 2012
    Essex
    118
    I can easily expand:
    3.0L V6 TDI Jan 2007 B7 Chassis Auto gearbox No DPF 111k miles
    27,038
    Quote Originally Posted by ScottB5 View Post
    Keep it on topic Scott.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,968
    On it.
    Quick google brought up nothing.
    A polish site suggest checking the cables, fuses and plugs.
    I'm out of ideas.
    Mar 2012
    Essex
    118
    Cheers Scott, thanks for your help. I'll report back later...
    Jan 2011
    Aberdeenshire
    646
    A couple of wiring invest thoughts, applicable to most sensor/loom combination faults......
    A short to ground suggests a short to ground - a connector full of fluid or chaffed loom would cause this
    An overtemp (or 'High' or 'Low' fault) in combination with the above suggests a connector needs cleaning, or a loom has chaffed (causing a short/open circuit) on the temp (or whatever) sensing line.
    Both of the above could also be caused by breakdown of the module, assuming it's common to both, although I would have expected a module fault code.
    They may also be caused by a breakdown of the temp sensor (short/open circuit causing high reading and short to ground fault)
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    May 2012
    RETFORD, NOTTS
    1,749
    The op originally posted a full log but NHN edited it and asked for a full log purely to wind up scott!!! hahahahaha
    The evidence:
    The original post was edited:
    Then NHN reply to this post also 2 weeks ago:
    And then scottb5 gets upset!
    Originally Posted by ScottB5 but that single line on its own about posting more winds me up.
    I daresay i will be edited out now too lol... but hey it breaks up the day :P
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    27,038
    I'm afraid you're wrong on all counts, nothing was removed from his log at all, he didnt post a full log, he posted up the 2 logs in a table, which I copied & added to his 1st post & the OP was made aware via PM which he acknowledged.
    So rather a pointless friction causing post IMHO.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,369
    Quote Originally Posted by @udi A3 View Post
    The evidence:
    Tut tut Tom, please find some other way to break up your day please.
  1. Help with Fault Codes
    By Daniel Storey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2011, 12:36
  2. Help With Fault Code 00562 - Oil Level - APY Engine
    By darreng1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th October 2010, 17:43
  3. some help with fault code??
    By mattm in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2008, 19:49
  4. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  5. Help with Fault Code
    By madkebab in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd February 2006, 13:15
