Hi all.
I have a Audi A3 8P MY2010 with Xenons + LEDs.
Been trying to follow Ross-Tech advice on activating DRL to no avail.
My light switch doesn't have the DRL selector on it (as can be seen in the following photo), only three positions and i would like the LEDs to turn on even with the switch turned off.
here's a full scan:
Here are the screenshots of the relevant bytes
Even with the settings like that the damn leds stay off
Any help would be highly appreciated!
here's a full scan:
Code:
Wednesday,13,February,2013,17:02:03:52796
VCDS Version: Beta 12.10.2 (x64)
Data version: 20121222
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72 77
VIN: WAUHF28P7AA052XXX Mileage: 42710km/26538miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 8P0 907 115 AE HW: 8P0 907 115 Q
Component: 2.0l R4/4V TFSI 0020
Revision: AAH07--- Serial number: AUX7Z0I7FNR00R
Coding: 0103100C1C070160
Shop #: WSC 06314 000 00000
VCID: 75E12DD31C0F0AB6ABB
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Mileage: 42395 km
Time Indication: 0
Date: 2013.02.04
Time: 20:14:28
Freeze Frame:
RPM: 837 /min
Load: 30.6 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 50.0°C
Absolute Pres.: 940.0 mbar
Voltage: 13.208 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 051 R HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1926
Revision: 04844002 Serial number: 00000908241237
Coding: 0000020
VCID: 224B268FFD01CD0EBE9
No fault code found.
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 144260120A2700FC281206E9501A00413900
VCID: 800FCC0713CDBF1E08D
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BK HW: 8P0 820 043 BK
Component: KlimavollautomatH09 0140
Revision: 000496 Serial number: 8P0820043BK
Shop #: WSC 00000 000 00000
VCID: 76E32ADF010901AEA21
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 D HW: 8P0 907 063 D
Component: BCM PQ35 M 105 0563
Revision: 00105 AI
Coding: 06000A2CB005F2C0207241E000000914410E2BAA304DD929640008840040
VCID: 3561EDD39C8F4AB66BB
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB002VAD%
Coding: 30314238303830303131554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FADBF3B16131066417
Crash sensor for side airbag; driver side:
Serial number: 3572DRB400009625418L
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB400009644EA8%
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB400004FAB46D
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB400004FAA81AY
Crash sensor for front airbag; driver side:
Serial number: 35547RB40000504F6B2N
Crash sensor for front airbag; passenger side:
Serial number: 35647RB40000504F6ADY
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 46839A1F3169D12EF21
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 F HW: 8P0 920 932 F
Component: KOMBIINSTR. VDO H03 0980
Revision: D0H03003 Serial number: 2247I003001459
Coding: 0000128
Shop #: WSC 04576 659 119544
VCID: 377DE7DB4683B8A6797
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 5223
Revision: H16 Serial number: 4120K0990704DC
Coding: ED817F06100602002102
VCID: 66C37A9F51A9F12E121
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03003 Serial number: AUX7Z0I7FNR00R
Shop #: WSC 04515 659 93121
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0000148
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 233 2901
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 2F6DDFBBBED37066217
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158949357486
VCID: 3663EADF418941AE621
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0000148
VCID: 479D971B3663C826097
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: FAFBBEEFB511E5CE469
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 T HW: 8P0 035 186 T
Component: R Concert2+ H02 0280
Revision: 00H02000 Serial number: AUZ1Z3I5335722
Coding: 0730012
VCID: 4385830B025BE406D5F
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 428B860F1D41ED0EDE9
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000144
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H34 0600
Revision: 00000000 Serial number: 00000005116276
Coding: 0001295
