Sky InsuranceVolks Autos
Results 1 to 8 of 8
    Dec 2012
    241
    Adaptions not working?
    I recently changed the number of comfort turn signals from 3 to 4 on my 2010 S3 sportback, tested it whilst in the car and it did 4 indicator blinks. Next time I used the car only 3 blinks happen? I had a look at the adaptions and it still says 4, so I click save again and 4 blinks work, next time I use the car it's back down to 3 but the coding still says 4?
    Anybody know why it's happening?
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    27,072
    Do a battery disconnect, try again, if still does then have audi look at it.
    Dec 2012
    241
    Thanks for the tip! I'll try that this morning as its going in to Audi tomorrow anyway, and if its still playing up I'll ask them to have a look.
    Have you had this problem on any cars before?
    Dec 2012
    241
    Tried the battery disconnect for 30 mins did the adaption again, it worked, turned the ignition off and back on tried again still worked, left the car for an hour went out an tried... back to 3 blinks. So I'll tell Audi about it tomorrow
    27,072
    Its not holding, have you checked in dis if there is an option for setting this comfort system?
    Dec 2012
    241
    I haven't but I will do before I mention it to Audi
    Dec 2012
    241
    Just checked in the DIS, it has an option to have the convenience turn signals on or off, so at the moment one gives me 3 blinks even tho it should be 4 and off gives me 1. Hopefully Audi can sort it
    mfractal's Avatar
    Jun 2007
    47
    yep, same here. A3 8P MY2010. Set it to 4, test it, it's 4. Remove key from ignition - goes back to 3 (even though vcds shows 4)
  1. Adaptive cruise control not working
    By bigcw in forum RS6 Forum
    Last Post: 8th July 2013, 13:57
  2. Rear speakers not working
    By V1RDE in forum In-Car Entertainment
    Last Post: 1st November 2003, 16:47
  3. Brake Lights not Working!! HELP!!
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2003, 12:41
  4. URGENT - BRAKE LIGHTS NOT WORKING!!
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2003, 21:57
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
