EM TuningVolks Autos
    mike-turbo's Avatar
    Sep 2009
    80
    traction control light on !!help needed
    hi ive got a golf plus 2011 i needed to change the steering rack after a small bump then i had the yellow steering light on and the traction control light on i took it to be tracked and now the yellow steering lights gone out ive just got the traction control light on ive tried the basic settting but no luck ive scanned it and this is what ive got.
    Saturday,26,January,2013,11:23:24:27260
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 7N0
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
    VIN: WVWZZZ1KZCW501652
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 MM HW: 03L 907 425 C
    Component: 1,6l R4 CR td H43 9050
    Revision: --H43--- Serial number: 00000000000000
    Coding: 08114034032501080000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_ECM16TDI02103L906023MM 003006
    ROD: EV_ECM16TDI02103L906023MM_VW36.rod
    VCID: 7DFBFA77EC9B12F04AA
    No fault code found.
    Readiness: 1110 1000
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 263B400D092200FB641102E9901B0091310000
    VCID: 7BFFF46FFA8F1CC074E
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 131
    Mileage: 6180 km
    Time Indication: 0
    Date: 2013.14.28
    Time: 11:21:14
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 29184
    Count: 295
    Count: 46336
    Count: 0
    Count: 1015
    Count: 0
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 131
    Mileage: 6180 km
    Time Indication: 0
    Date: 2013.14.28
    Time: 11:21:14
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 29184
    Count: 166
    Count: 46336
    Count: 0
    Count: 1015
    Count: 0
    Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
    Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
    Component: AC Manuell H19 0304
    Revision: 00001015
    Coding: 0000004003
    ASAM Dataset: EV_ACManueBHBVW36X A01010
    ROD: EV_ACManueBHBVW36X_VW36.rod
    VCID: 7F07007FE69700E0586
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 084 F HW: 1K0 937 084 F
    Component: BCM PQ35 B 110 0651
    Revision: 00110 AC
    Coding: 4C180A3A8825F1E0400800C0340000E44B510E88436D896064 8087000041
    VCID: 31631647684326909E2
    Subsystem 1 - Part No: 5M0 955 119 D
    Component: Wischer 24051 26 0513
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AG Labels: 1K0-955-559-AG.CLB
    Component: RLS 240511 05 55 0403
    Coding: 4230BB
    Subsystem 3 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Subsystem 4 - Part No: 1K8 951 605 B
    Component: LIN BACKUP HO H11 9005
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 131
    Mileage: 6180 km
    Time Indication: 0
    Date: 2013.14.28
    Time: 11:21:42
    Freeze Frame:
    Term 15 On
    Voltage: 12.90 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
    Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
    Component: PARKHILFE PLA H08 0116
    Revision: -------- Serial number: 13991111968484
    Coding: 10900B
    VCID: 48955BA3FBD98758A9C
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
    Component: AirbagVW10 013 0613
    Serial number: 003G6RA26SKW
    Coding: 00003236
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3261194B65451D88E78
    Crash sensor for side airbag; driver side:
    Subsystem 1 - Part No SW: 5M0 955 557 HW: 5M0 955 557
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME1D58225EZZZ0
    Crash sensor for side airbag; passenger side:
    Subsystem 2 - Part No SW: 5M0 955 557 HW: 5M0 955 557
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME5929235EZZZ0
    Crash sensor for side airbag; rear driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3511HSME73261D27ZZZM
    Crash sensor for side airbag; rear passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3521HSME752F1D27ZZZY
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90422KEK0010F
    Coding: 5080140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_VW36.rod
    VCID: 70E5D343ABC96F98D1C
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5M0 920 972 A HW: 5M0 920 972 A
    Component: KOMBI H03 0607
    Coding: 470B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 306513436B492F9891C
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 J HW: 1K0 907 951
    Component: J533 Gateway H43 1620
    Revision: H43 Serial number: 270511F1000596
    Coding: 359003
    VCID: 3777285F8627F8A0D06
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 131
    Mileage: 6180 km
    Time Indication: 0
    Date: 2013.14.28
    Time: 11:22:40
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0607
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EAD1412B0D1515481F8
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 5K0 959 701 G HW: 5K0 959 701 G
    Component: Tuer-SG 009 2122
    Coding: 0131764
    VCID: 3669255B412D01A8CB0
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 233 3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    VCID: 346D1F53575113B8F54
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 5K0 959 702 G HW: 5K0 959 702 G
    Coding: 0132020
    VCID: 3777285F4627F8A0D06
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
    Component: Radio RCD310 031 0075
    Revision: 01000001 Serial number: VWZ1Z2L3402368
    Coding: 0500040004000A
    VCID: 336F1C4F925F1480ECE
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H43 1620
    Coding: 030B185A
    VCID: F1E3564728C3E6905E2
    Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
    Component: J367-BDM H07 0180
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 5K0 959 703 E HW: 5K0 959 703 E
    Component: Tuer-SG 007 2101
    Coding: 0131216
    Shop #: WSC 01357 011 1012552
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 E HW: 5K0 959 704 E
    Coding: 0131216
    27,029
    You possibly will have to advise the rack its got an internal steering angle sensor, then calibrate the sensor as per the wiki online at ross-tech, check in module 44 & see if there's an adaption channel to state it has an internal angle sensor.
    mike-turbo's Avatar
    Sep 2009
    80
    Sorry to sound stupid but what do you mean by advise? the rack
    27,029
    Code it is probably the better word
    mike-turbo's Avatar
    Sep 2009
    80
    Oh thanks but i will try what you said a get back to you.
  1. Haldex pump running, traction control light on. help please.
    By Oke Phill in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2012, 19:25
  2. Traction control light on help??
    By marlowA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2010, 12:59
  3. Traction control light help!
    By a3-se in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2009, 14:58
  4. Traction control light and fan please help?!!!!!!!!!!
    Last Post: 6th November 2009, 22:25
  5. Traction control light staying on
    By monty77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2005, 15:59
