Chris NottMonster Motorsport
View Poll Results: Is a VCDS easy to use ?
Voters
12. You may not vote on this poll
  • Very Hard
    0 0%
  • Hard
    2 16.67%
  • Moderate
    1 8.33%
  • Easy
    5 41.67%
  • Very Easy
    4 33.33%
    Audi Dynamik's Avatar
    Sep 2011
    2,121
    Hi i would like your opinion on a poll of how easy/hard a VCDS is too use.
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    Feb 2011
    Leeds
    176
    VCDS has a variety of functions. The ease of use I think is more down to what each individuals knowledge of the elements of the program. I have never used VCDS before I used mine, but found it incredibly easy to scan for faults and reset them, and with good instructions available online anyone who is confident enough to go further into their cars settings I cant see it being much more difficult
    A3 TDi 196 Bhp 340 ft-lb
    The Build Thread
    Darkside Map, PD150 turbo, Allard FMIC, SFS Outlet pipe, Polybushed, Forge Short Shift , LCR Brembos, 17 TT Comps, AP Coilovers, S3 Recaros
    27,089
    Exactly, all comes down to the level of technical ability, but I have had some clients who have admitted to being totally illiterate with pc's & never had them comeback with an issue using vcds.
    Logic & common sense denotes things tbh, but overall its easy to use for basic things & as you become more aware of the abilities, you learn how to use more functions which become easier aswell, for overall it gets an easy vote from me.
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,102
    Agree with the above. An important rule is before you make any changes, take a note of the previous setting!
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    Quote Originally Posted by Grant View Post
    The easiest way to do this is to save a scan before changing ANYTHING, all the codes will then be stored if you mess anything up or introduce a DTC.
    Basic DTC scans are easy, as are long code changing, it then gets a bit more complex if you need to change the codes via the binary or the long code itself.
    It’s not rocket science…. just make sure you do your homework 1st.
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
    Feb 2011
    Leeds
    176
    As i said earlier its very much down to research and careful use. I have done a few scans of my car now and sorted at least 3/4 of the problems I had. A simple search of the forum and google has meant that I have activated the lock alarm chirp on my car with no hassle at all with no previous knowledge VCDS. I must commend Ross-Tech on their fantastic product which has certainly developed the VAG community
    The Build Thread
  1. How use VAGCOM/VCDS to test for boost & vac leaks
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 1 Week Ago, 20:51
  2. Checking genuine mileage using VCDS ??
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2014, 13:44
  3. Replies: 5
    Last Post: 28th February 2011, 19:16
  4. Offset Calculator- clear and easy to use
    By crazypainter in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd February 2011, 22:16
  5. Using VCDS to give quarter mile / 0-60 times
    By lincoln_dj in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th June 2010, 17:54
