JMB RetrofitsEM Tuning
    Sep 2012
    Prague, CZ
    88
    Auto lights sensitivity - 8P3
    I've searched hi & low and can't find the definitive answer for this - my auto lights are too sensitive / coming on when its still daylight.
    I've also had a good look around VCDS and have found the following settings (8P3/2009 A3 with Bi Xenons & Auto Wipers / Lights):
    09 Central Elect. > Long Coding > Component: Component: REGENLICHTSENSORH04 0003 > Coding:
    Byte 0, Bit 3-4:
    00 Light Activation Threshold normal
    08 Light Activation Threshold earlier (+20%)
    10 Light Activation Threshold earlier (+40%)
    18 Light Activation Threshold earlier (+60%)
    Am i correct in thinking that this will make the light sensor more sensitive? (the opposite of what i'm trying to achieve)
    Byte 02, Bit 0-7:
    Here are various options relating to glass and vehicle type - does the higer % make the sensor more sensitive or less sensitive?
    I also read somewhere that adjusting the Intermittent wiper setting on the wiper stalk increases / decreases both rain senor and light sensor sensitivity - would this be true on my 2009 A3?
    VCDS extract:
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Coding: 00150573
    Shop #: WSC 12345
    Sep 2012
    Prague, CZ
    88
    Corrected image*
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    305
    I set mine to the lowest setting a few weeks back, I think it was 32%
    Coming out of a multistory car park into daylight, the headlights went off in a few seconds.
    On a fair warning though, when we were released from work because of the snow the other week, the lights took ages to switch on even though it was snowing, I thought about actually switching the lights on manually (god forbid) so perhaps 32 is too low, I may go up to around 40 (default was in the 60's from memory) S3 BE
    +incoming (64/Sep 1st) S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
  1. Auto Lights
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th August 2007, 21:43
  2. Retrofit auto lights with coming home feature
    By pav767 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2006, 18:52
  3. Auto lights
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2006, 11:10
  4. Flashing Auto Light Indicator
    By cadders in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2006, 10:39
  5. Wierd timed / auto lights problem
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd March 2005, 19:47
