Badger5Chris Nott
Results 1 to 14 of 14
    Jan 2013
    31
    Unhappy New TT Owner With Problems need VAGCOM scan to my car plz
    Hi Everyone, so I finally decided to buy an Audi TT, thought I should get an oldish one for now, just to see how I like driving them and overall quite happy. Although Ive now had a few lights come on the dash and not sure what they are? Is anyone able to help at all so that I can avoid being ripped off by audi dealers. If there was anyone local (Romford) who could come or I can go to them and do a diagnostic as a good will gesture I would be really appreciative and also advise me of what to look for in the car. As the seller was very dishonest now im suffering from it. Hope someone can help.
    Thank you ( " ; )
    The roof is securely closed but the signs on?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,441
    Where are you located? x
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,474
    hes in essex
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,441
    hes in essex
    Lee, you know what my geography is like, lol. Romford is not a place im familiar with, i needed a bit more info, btw, you can stop laughing now. x
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,441
    27,083
    I wont be back in that area until next week now, maybe someone else closer can assist.
    Jan 2013
    31
    Aww such kind people trying to help me out thank you! If anyone's near brentwood, romford or I can pop to you locally Lakeside way?
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    882
    Re: New TT Owner With Problems need VAGCOM scan to my car plz
    Doesn't look like the engine is running in this pic? If this is the case, the lights should go out when the engine is started.
    Jan 2013
    31
    Quote Originally Posted by ShaunS3 View Post
    your right the engine is not running but these are the light which stay on when the engine is running
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Does it feel hesitant when you drive it? Or do the revs fluctuate? The EPC light might be crank position sensor.
    The traction control light could be ABS sensors - I've just changed one front and one rear (and the wiring to the front) as that was causing the ABS light and traction control light to come on. Bought the sensors from eBay for £5 rear and £8 for two fronts.
    The roof might just need a new switch as it's not picking up that it's closed.
    VCDS Lite cable is £17 delivered from eBay and you get a good amount of codes but you need to register it which costs £60 I think. I just Google the code numbers that aren't shown. It's a handy cable to have even just to point a garage in the right direction.
    Don't feel disheartened by a bad seller. A few fixes and you've got the car you wanted. A service wouldn't go amiss either if the previous owner hasn't taken car of it. New oil and oil filter as a minimum. And clean that dead skin off the dash
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Jan 2013
    East Midlands
    22
    put codes into here and will tell you whats up with the car - Category:Fault Codes - Ross-Tech Wiki
    27,083
    It wont tell you whats wrong with your car, it merely gives you some possible areas to check, some errors can be brought on by other issues, so beware you research & check properly before condemning a part.
    Jan 2013
    East Midlands
    22
    what do u charge for a full copy of vagcom m8 i have the lite version and can do most thing's i only need the disk ?
    27,083
    You dont buy the software, vcds lite will never have the same access as the proper system, you need to upgrade your cable to the hex-can-usb of which I sell, which allows the full software to be used without restriction, pm for a price.
  1. New TT Owner With Problems
    By yummymummy in forum The Welcome Section
    Last Post: 16th January 2013, 12:38
  2. new a4 owner with a problem, and saying hiya!!!
    By mrpies in forum The Welcome Section
    Last Post: 14th January 2009, 12:07
  3. New TT owner with window problem
    By trophy160 in forum TT/TT-S/TT-RS Forum
    Last Post: 5th April 2008, 15:50
  4. 89 Cabriolet (1993 model) - new owner with problems!
    By tonywitney in forum Classic Audi Forum
    Last Post: 15th August 2007, 22:55
  5. Big favour needed from New A3 owner (with armrest)
    By garethj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2005, 12:17
