AH FabricationsJMB Retrofits
Results 1 to 8 of 8
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    P9571 fault code help
    Hi.
    I have a code that is coming up:
    009571/P2563 - Turbocharger_Boost_Control_Position_Sensor_Circuit
    Once I have been travelling at motorway speeds for over about 15 minutes, if I then pull over, put the car in neutral and leave it ticking over. The MIL starts flashing after around 5 seconds.
    On short journeys around town the light doesn't flash.
    Can anyone help?
    I have already had the actuator, pressure sensor and N75 valve replaced.
    Chris
    2008 A3 2.0 TDi 170
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Hi.
    Can anyone help?
    Chris
    2008 A3 2.0 TDi 170
    27,094
    Please keep it in one thread, not 2, as makes a mess of the problem, so where would you like to have the thread to continue & the other will be removed.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    i didn't realise this section existed until after I posted in the A3 section and couldn't remove it.
    Please remove it from the A3 section
    Jun 2011
    138
    Possible Causes
    • G581 Faulty
    • Wiring and/or connections faulty
    • ECM faulty
    Possible Solutions
    • Check fuses
    • Check wiring and connections
    • Ohm test G581, see factory repair manual
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    27,094
    170 has an electrical actuator afaik, check wiring to it.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Yeah think i'll check the wiring.
    As i've had those new parts fitted everything should be working ok.
    I've been told that the adjustment on the actuator is quick tricky to get spot on, i might have to go to a specialist I think. Dread to think what Audi would charge.
    What does it mean by ECM faulty?
    27,094
    electronic control module.
  1. Fault codes help
    By Andy_S3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd December 2008, 20:27
  2. 2.8 V6 fault codes help
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2008, 18:00
  3. fault code help
    By Audi_nut in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2008, 20:33
  4. fault code help
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th June 2007, 23:43
