Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    monopole's Avatar
    Oct 2012
    240
    yet another balls up
    Having had a problem with my xenon light range and dealing directly with Nigel (turned out needed VCDS 12.10.2 beta to resolve) I again attempted to try and get the TPMS to work
    I followed and selected the following;
    17 - Instruments
    - Coding
    -- Added +16 to the first 4 digits
    03 - ABS / Brakes
    - Coding
    -- Long Coding Helper
    --- Byte 16
    ---- Tick Bit 2
    03 - ABS / Brakes
    - Coding
    --- Byte 17
    ---- Tick Bit 2
    I had the TPMS "tyre" on the display cluster when selecting ign on, and no "TPMS" fault on the DIS, so I thought hey presto, working fine.
    I went back in, and a short time later needed to go out. When I got back in the car I had an "ABS" light on the cluster.
    I fetched my VDS cable and laptop and when I select 03 ABS i get the following fault:
    Thursday,10,January,2013,10:38:24:58778
    VCDS Version: Beta 12.10.2 (x64)
    Data version: 20121222
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152
    Revision: 00H31001
    Coding: 1642801249250001681101E7921B0081390000
    Shop #: WSC 06314 123 12345
    VCID: 7DF7C4AFE414F4F6E3B
    1 Fault Found:
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 127
    Mileage: 4257 km
    Time Indication: 0
    Date: 2013.01.10
    Time: 12:18:42
    Freeze Frame:
    Count: 0
    Count: 14
    Count: 12800
    Count: 320
    Count: 50688
    Count: 0
    Count: 1
    Count: 0
    I looked and could'nt find any way to clear the fault, even tried VCDS 11.11.5 to see if it was a VCDS beta fault, but no such luck, the light is still there on the cluster
    any help greatly appreciated
    +incoming (64/Sep 1st) S3 (300) Sportback S-Tronic Quattro Phantom Black
    -outgoing (63) A5 2.0TDI (177) Black Edition S-Tronic Coupe Quattro
    Phantom Black
    VCDS Location: NI (East Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    A3Kent's Avatar
    Different Gear
    May 2012
    1,026
    You got a brand new car there mate with warranty? Take it back to Audi to fix.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,397
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Quote Originally Posted by A3Kent View Post
    He can't go to Audi for a warranty claim on trying to activate the TPMS which his car wasn't originally set up with.
    Has to be to do with something done whilst trying to activate it. This bit "01486 - System Function Test Activated" seems strange.
    Mono - Have you tried rolling back the changes and seeing if you still have the fault?
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi Bluetooth -AMI/iPod - RNSE Navigation Units - Cruise Control - Optical Parking Systems - DAB (Digital Radio)- Audi Factory Retrofits- Stolen Vehicle Tracking - In-Car Cameras- Genuine VCDS Cables
    monopole's Avatar
    Oct 2012
    240
    yes mate everything is back as set from original scan, still get the ABS warning light showing this fault
    this is a copy of the before and after codes, as you can see, they are the same:
    Revision: 00H31001
    Coding (before): 1642801249250001681101E7921B0081390000
    Coding (after):.. 1642801249250001681101E7921B0081390000
    Shop #: WSC 06314 000 00000
    VCID: 7DF7C4AFE414F4F04AB
    [EDIT]
    This is the code with the TPMS changes: 1642801249250001681101E7921B00813D0400, so yeah, it is now definatley back to original
    Phantom Black
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,209
    Follow Brodster On Twitter Add Brodster on Facebook
    This TPMS activation seems to be a right pain in the a55 for some and not for others......very strange.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/VCDS/Wagner
    26,744
    You must contact Ross-tech to get the procedure to disable the system function test, you've been playing & enabled something you shouldnt have :P
    May 2012
    RETFORD, NOTTS
    1,707
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    monopole's Avatar
    Oct 2012
    240
    Cheers guys, I think ill send the cable back to nigel, im obviously a potential disaster waiting to happen
    Ill give the test a try, should have some space in the car park at work either tomorrow or over the w/e.
    (Dont worry m8, im not gonna send it back)
    Phantom Black
    26,744
    No mate, you're not, just need to not click things unless you know what they do lol.
    May 2012
    RETFORD, NOTTS
    1,707
    I suppose i should confess, I did exactly the same when i first got my vcds cable! I watched the you tube video to perform the test and it took about 4 attempts.
    26,744
    Hey we're all mortals, I've made mistakes, luckily not bad ones, but still mistakes lol.
    monopole's Avatar
    Oct 2012
    240
    Cheers again guys
    Arrived at the empty car park at work this morning, held my foot on the brake for a few seconds the ABS light started flashing. I pulled off to about 12mph turned left, turned right, ABS light went out
    now I need to get back to sorting TPMS...........................
    Phantom Black
  1. Yet another thing - I am at the end of my patience with the S3
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2005, 17:26
  2. Yet another induction kit question
    By imported_DeadEye in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2005, 13:55
  3. Yet another 'bored on a friday afternoon' thread.
    By RichA3Turbo in forum General Chat
    Last Post: 26th November 2004, 22:27
  4. yet another dump valve question!!
    By spencerjoel in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2004, 08:11
  5. Yet another speeding ticket, 245 (160GBP)!!
    By Gambba in forum General Chat
    Last Post: 31st July 2003, 11:41
