Badger5Monster Motorsport
    Jul 2012
    Salisbury, Wiltshire
    41
    Anyone with VCDS pass through/near Salisbury at all?
    Hi all,
    Can't see anyone too close to me on the users map, just wondering if anyone ever passes near me? For some reason if I floor my car in 5th at low revs, it kinda goes into a semi limp mode. So once I shift down and try to accelerate in a lower gear, not a lot happens, takes ages to get up to speed!
    I have been advised to take a look at my fault codes, will hopefully find out whats up! I have a rolling road day 2nd of Feb, so would be nice to fix the problem before then!
    It's a '95 Coupe 2.6E, I have the cable for 2x2 to 16pin (IIRC)
    Thanks in advance,
    T
    '95 Coupe 2.6E | '91 Mk2 Golf GTD
    27,075
    What happens if you stop, cycle ignition, is it back to working properly?
    Jul 2012
    41
    It's a bit random. Sometimes I can stop for 2 mins, go again and it's fine. Other times I can park up for 20 mins, and it's still doing it.
    Can be when the engine is hot or cold etc. Very confusing...
    27,075
    There was a guy called Stu down near your area, but he's not been on here for ages.
  1. Anyone with VCDS / VAG-COM in Essex (or near S.Woodham Ferrers)
    By .Jas. in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th December 2012, 23:17
  2. Anyone with VCDS hex-can interface near Bradford, your help needed please
    By 22imy22 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2011, 22:42
  3. Anyone With VCDS HEX-CAN interface near Bradford, your help needed please
    By 22imy22 in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th July 2011, 19:38
  4. Anyone with VCDS near Coventry?
    By exciter01 in forum General Automotive Chat
    Last Post: 20th March 2011, 16:53
  5. Anyone with VAGCOM, York or near?
    By Lloyd149 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2010, 20:19
