Chris NottVolks Autos
Results 1 to 7 of 7
    Jun 2011
    Melbourne
    230
    Strange Ignition Off Behaviour. Please have a look at my VCDS Fault List
    Hi All,
    I've had this issue for about a month. Usually used to turn off the car and while key in ignition, I can still use the phone through the bluetooth, doors still tocked and interior lights are still off, as soon as i take the key off the bluetooth is off, doors unlock and interior lights come on. lately the bluetooth goes off, doors unlock and lights come on as soon as i turn off the car and even before the key is in the position to be removed.
    I did a fault code scan and initially I had the same faults as below but there were also faults showing in the detail section of each module. Once I reset the faults and tried again, they only came up in the main section (I didnt turn off and on the car). I should have saved the previous scan but did not!!. The radio (56) one been there forever, and i think its due to the IPod connection kit. What's new are No9 Cen Elec. (the module detail said short circuit in the LED light or something, i was running LED Bulbs and to get rid of the error i switched it to the Bi xenon with LED DRL, but i have since put it back to normal and they are running fine). The Steering wheel im assuming is what's causing the issue described above. Finally the cent conv, this has been the same for ages but i have not noticed any issues. Could anyone shed some light on my issues. Many thanks
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,928
    give ot a few days and rescan
    so you can save the codes
    Jun 2011
    Melbourne
    230
    Cool. Il give it another go. Strange thing is despite the codes, the car runs fine.
    26,720
    Sounds like ignition barrel to me mate.
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    That would be my guess as well Nige as it is common to all those things, and their behaviour relative to ignition position.
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    Jun 2011
    Melbourne
    230
    Thanks guys. Heard the same from another oz Audi member. I recall seeing that on the fault code prior to myself clearing them. Would this be the part no I need: 1K0905865A?
    Any DIY? I did a search but found one for the 8L but not the 8P?
    Jun 2011
    Melbourne
    230
    Quote Originally Posted by NCRAW View Post
    anyone can confirm the part no pls?
  1. Water pump running on after ignition off & draining battery - help please
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2011, 08:00
  2. help please? going to have a look at this a3 1.8t, advice please
    By MoAudi1.8T in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2008, 13:17
  3. Have a look at this New Zealand speeding ticket!!
    By Soupie69uk in forum General Chat
    Last Post: 24th June 2005, 07:42
  4. Have a look at these...
    By TDI-line in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2005, 16:49
