Badger5EM Tuning
    May 2012
    RETFORD, NOTTS
    1,753
    G450 replacement and adaption?
    Ive just found the following on a friends A4 2008 3l v6 quattro
    Sunday,30,December,2012,13:54:38:05185
    VCDS Version: Beta 12.10.1
    Data version: 20121121
    5162 - Diesel Particle Filter; Differential Pressure Sensor
    P2453 00 [237] - Implausible Signal
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 131863 km
    Date: 2008.04.10
    Time: 21:07:57
    Now googling around suggests this sensor needs calibrating/adapting when replacing, what is the process for doing this?
    Ive checked the soot level and it was around 14g, but with a dodgy sensor that might not be accurate. The car doesnt seem down on power, the engine light and coil light come on shortly after resetting though.
    Thanks, tom.
    EDIT:
    Engine was recently replaced with a second hand unit (sucked up water), if the replacement engine had a g450 on it, would this need calibrating to the cars ecu? In effect if this happened, could putting the original sensor back on fix it?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    27,126
    Implausible signal usually denotes its got an issue with sensor, not neccessarily needs calibrating, by these guys advice who are fairly well knowledged, they say replace sensor & force regen, cant guarantee will fix but its definitely the best way forward IMHO.
    Audi A4 2.0 TDI 170 MY2009 DPF fault codes
    May 2012
    RETFORD, NOTTS
    1,753
    I did find that thread on google, and they suggest calibrating it. from vcds menu I could see a reset learnt values, maybe thats the one. Car developed a fuel leak so wasnt able to complete a regen, but the new senser has been ordered now.
    May 2012
    RETFORD, NOTTS
    1,753
    To answer my own question,
    After fitting the g450 sensor adaption is simply as follows:
    Select engine (01)
    Login or coding 11
    Type 30605 in the box and login.
    Close controller,exit vcds. Switch ignition off ( i jumped out and locked the car for 30 seconds to be sure to send everything to sleep.
    Job done.
  1. Key Fob battery replaced and still doesnt work
    By beerglass in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th August 2010, 22:37
  2. Replacing and re-coding dash clocks in S4?
    By calvin in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th January 2010, 20:32
  3. 1999 A3 1.6 8v Lambda replacement and brakes issue
    By ontheball247 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2009, 02:55
  4. A4 1.8t Power Steering Rack Replacement and Flushing System
    By THE MONSTER in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th November 2009, 23:25
  5. DRL replacement and fire extinguisher
    By sakkie69 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2008, 13:13
