Chris NottSky Insurance
    chris1988brown's Avatar
    middlesbrough
    578
    exhaust pressure sensor G450
    hi guys my girlfriends golf gt tdi 170 has the dpf light on and ive done forced regen which clears all the lights and runs fine for too days then comes back on , the partticular filter get to 80-110% full depending how long it goes with the light on before i do a forced regen, i pluged in again last night and put the fault code in ross tech and it comes back with possible faulty exhaust pressure sensor g450 or possible faulty dpf , how can i check if the exhaust pressure sensor is working OK i cant find the sensor in the measuring blocks , any help would be great
    below is a copy of the fault code reding
    Tuesday,04,December,2012,22:02:22:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Address 01: Engine Labels: 03G-906-018-BMN.CLB
    Control Module Part Number: 03G 906 018 FC HW: 03G 906 018 FC
    Component and/or Version: R4 2.0l PPD1.2 4357
    Software Coding: 0000072
    Work Shop Code: WSC 00791 210 86443
    VCID: 6BDFD9754A9ED11
    2 Faults Found:
    008194 - Particulate Trap Bank 1
    P2002 - 006 - Efficiency Below Threshold
    Freeze Frame:
    Fault Status: 11010001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 120440 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 21:57:26
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    (no units): 3.0
    Pressure: 0.0 mbar
    Lambda: 228.2 %
    Time: 4492.8 s
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 120440 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 21:57:26
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    (no units): 3.0
    Lambda: 228.2 %
    Pressure: 0.0 mbar
    Time: 4492.8 s
    Readiness: N/A
    cheers chris
    MY S-LINE 2.0TDI HYBRID PROGRESS
    MY PROGRESS THREAD
    27,029
    You're using a chinese knockoff counterfeit cable, the forum doesnt support the use of these I'm afraid, if you get genuine, then I & Ross-tech will be happy to help you further.
    middlesbrough
    578
    really ?? i paid £100 for this cable second hand
    MY PROGRESS THREAD
  1. Error 001137 Exhaust Pressure sensor Fault. Advice
    By a3mad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2013, 12:33
  2. faultcode exhaust pressure sensor a3 1.9 tdi
    By johnboy11 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2011, 16:01
  3. how to change oil pressure sensor ?
    By AUDI@WRC in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th May 2008, 21:50
  4. Barometric pressure sensor
    By squale in forum General Technical / How To
    Last Post: 21st January 2008, 22:44
  5. oil pressure sensor
    By litfoo in forum Classic Audi Forum
    Last Post: 16th June 2005, 23:27
