Volks AutosJMB Retrofits
Results 1 to 18 of 18
    rdfcpete's Avatar
    Apr 2008
    123
    Headlight Washer Frequency (MY10 8P3 A3 BE)
    Guys,
    I've set the headlight washer activation frequency value in the adaptations in the CE Module to every 254 pulls of the screenwash stalk. It was spooling the HL washers much too often and I was rinsing through screen wash, as well as dirtying a clean car lol.
    Having set the frequency to 254 (maximum value being 255 if I recall), they still spool and squirt much much more often than every 254 times using the screen wash squirt- it might even be every single drive that this value resets - is that true?
    I want them to work but come on once in a blue moon, particularly as we're in 'Xenon on for most driving time' territory now.
    It's an 8P3 MY10 A3 Black Edition.
    Pete.
    Vagcom.biz's Avatar
    Official VCDS/Vagcom Seller
    Nov 2012
    Everywhere
    6
    You can set them to come on in a certain number of screen washes aswell & also how long before they activate when pulling stalk, so try adjusting the latter, not frequency.
    rdfcpete's Avatar
    Apr 2008
    123
    Quote Originally Posted by Vagcom.biz View Post
    You can set them to come on in a certain number of screen washes as well & also how long before they activate when pulling stalk, so try adjusting the latter, not frequency.
    That you Nige, different account?
    This is the adaptation value I've set to 254.
    Can't find anything else headlight washer related.
    What else should I be looking for, which module and where?
    I tested it right after my last VCDS session, switched the headlights on, pulled the windscreen wash stalk three times and it activated the HL washers and doused the clean car headlights in juice from them
    Thanks.
    Vagcom.biz's Avatar
    Nov 2012
    Everywhere
    6
    Quote Originally Posted by rdfcpete View Post
    Thanks.
    Maybe
    The delay option is for how long before the washer activates after you pull the stalk so to avoid it doing it all the time when pulling so a momentary pull of stalk for screen wash doesnt make it run or it should be, the other setting I've seen is how often it actiavtes when pulling stalk as in it activates every say 3 pulls of stalk makes the washers work once also, if you get me.
    rdfcpete's Avatar
    Apr 2008
    123
    Hmmm, interesting. When I've selected that option, that little popup box that describes the function says it's words to the effect of "Number of times you pull the windscreen wash stalk without the headlight washers activating", so it seems that is for that and I can't in which case find the headlight washer delay setting...
    If I pull the stalk quickly, or hold it on, it activates every single drive. Not sure what to do. I thought about taking the fuse out for them as they're pi**ing through screen wash and ruin my detailing work
    But all in all, I need them to work in an ideal world, just without being so frequent.
    Cheers.
    rdfcpete's Avatar
    Apr 2008
    123
    Any thing else I can adjust Nige? They're literally spraying every time I first use the windscreen wipe on every drive.
    Pain in das rear. In my MK5 Golf GTI (MY06 with factory winter pack) I didn't have this issue at all on it's headlight washers. It had the 25byte BCM too... Hmm.
    Jul 2012
    Cheshire/N Staffs
    1,352
    From (my rusty) memory:
    The figure nnn is multiplied by 50 to give you a figure in miliseconds.
    BUT
    If you car is MY10 then it may well have the later CE module, in which case the headlamp washer is controlled elsewhere, and will activate between 00 and 04 (1 and 5) pulls of the windscreen washer.
    Mine is set so that the headlamp washer activates every 5th pull of the windscreen washer - but to prolong the life of my screenwash, I normally just turn my light switch onto the sidelights position when I wash my screen, so that my headlamp wash doesn't activate !!
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
    rdfcpete's Avatar
    Apr 2008
    123
    Quote Originally Posted by veeeight View Post
    BUT
    Flicking to side lights isn't really going to be practical or safe for me to do, but I see the logic there...
    It is indeed the MY10 BCM and indeed everything is in the Central electronics module.
    I'm finding the newer BCM bit of a nightmare to find any practical long coding values for.
    There must be a setting somewhere in the CE module that controls this?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Maybe the better option is as mentioned above! set headlamp wash to activate after 2.5 seconds? that allows enough time to soak the windscreen without them activating.
    Sod's Law says even with them set to only wash every 254 times, it's going to happen every time you've cleaned the car.
    2009 A3 SB 2.0T DSG S line
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    I know you have the newer Module, but does the Long coding helper not work in a very similar manner to previous incarnations? and are the module changes so extreme?
    here's an image of MY09 module washer delay setting:
    BTW: this is in "Coding>Long Coding Helper", not "Adaptation".
    rdfcpete's Avatar
    Apr 2008
    123
    Quote Originally Posted by Artimus View Post
    Nope
    My CE module Byte 5 looks like thiiiis:
    Out of interest, if you change those values, which part of the '00110010' value string changes if I may ask?
    Thanks.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Sorry, didn't have time today, I'll try tomorrow.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Thanks.
    okay, just tested this and that string value doesn't change at all, what changes is the heading code ... i.e: when i set it at 20 instead of 50, the little box on line 3 with the value [32] changes to [05] or something similar.
    rdfcpete's Avatar
    Apr 2008
    123
    I appreciate you trying, thanks
    Not sure what that means either... I could try and guess a value to enter there and see what happens. As long as I record the current value it probably won't impact on much. Worst that can happen is it will reject the code and error on entry I suppose?
    I'm surprised in locking down the later CECM's/BCMs that Audi have taken away practical features like this, doesn't feature much logic to me.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    It might be worth a try, if I remember correctly [05] is the default value for a 1 second activation delay (which is where you're currently at) & it's looking like [32] somehow equates to 2.5 secs. Even if if it saves but doesn't work, everything you need to revert back to default is posted above.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    Just saw this today, not sure it's covered here & it might seem a bit obvious, but you might want to check in the same module that Headlight Washer Installed is selected - if you have such an option.
    rdfcpete's Avatar
    Apr 2008
    123
    I'll check this chief and feedback, ta.
    On a side surely, if that wasn't ticked, surely they wouldn't function at all(?) bearing in mind they were factory fitted when new?
    27,114
    Been away working Pete so havnt had chance to get back to this thread.
    You can certainly select disable headlight washer altogether, whether it will do so is another matter as it sees the connection, worth a shot.
  1. How Do Headlight Washers Work?
    By imported_kbininger in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2005, 20:16
  2. Headlight Washer Caps
    Last Post: 13th February 2005, 14:02
  3. Headlight washers!
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th December 2004, 02:20
  4. Headlight Washer Jets
    By greski in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th April 2004, 13:23
  5. Headlight washers
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd March 2004, 01:24
