Volks AutosChris Nott
Results 1 to 12 of 12
    slydog18's Avatar
    Jul 2011
    Luton, U.K.
    139
    First use of VAG.COM and now remote locking not working!! S3 8L
    I had my first tinker on my S3 8L with VAG.COM today to check/clear all fault codes, turn on beep with alarm and remove auto lock at 10mph. I cleared all codes and think I cleared something that I shouldn't have as I have got to my mums and found the remote alarm/locking is not working! I did have a control module memory fault in instrument cluster and got click happy when clearing codes!
    I have tried the learning remotes instructions including clearing on channel '00' before trying to pair the keys again but get no joy pairing them after saving 2 keys in the test and save area. I just get nothing when pressing either unlock or lock after saving and when I go back in it says there are '0' again.
    Here are 2 logs, one from before clearing fault codes and one after I got home from after realising they weren't working when I went out (I realise that I have a seatbelt problem from when I move my seat back and forth):-
    1:-
    Sunday,25,November,2012,10:53:37:31506
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    VIN: WAUZZZ8LX31204543
    Address 01: Engine Labels: 06A-906-032-BAM.lbl
    Part No: 8N0 906 018 BH
    Component: 1.8L R4/5VT 0001
    Coding: 10710
    Shop #: WSC 02629
    VCID: 78F469C358A859D8195
    WAUZZZ8LX31204543 AUZ7Z0B2120937
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E78BFDB3A0CA7E8139
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8L0 820 043 L
    Component: A3 KLIMAAUTOMAT 0105
    Coding: 00041
    Shop #: WSC 01236
    VCID: 316294E7FB5248909EB
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 L
    Component: Airbag Front+Seite 7008
    Coding: 01104
    Shop #: WSC 01236
    VCID: 4796DA3F65D6E620A0F
    Address 16: Steering wheel Labels: 4B0-907-487.lbl
    Part No: 4B0 907 487 F
    Component: Lenkradelektronik D01
    Coding: 01002
    Shop #: WSC 01236
    VCID: 2F66929FED665E6088F
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 R
    Component: KOMBI+WEGFAHRS. VDO D10
    Coding: 01444
    Shop #: WSC 00402
    VCID: 4280CB2B4EF4C308771
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 C
    Component: HALDEX LSC ECC 0010
    VCID: 204461A3A0B8F118015
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 00033
    Shop #: WSC 00652
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00953
    VCID: E0C4A1A360383118C15
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00014
    Shop #: WSC 01236
    VCID: E5CAB0B77F1A5430323
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8L0 035 195 H
    Component: symphony II NP2 0151
    Coding: 00205
    Shop #: WSC 00757
    VCID: 336E9EEF014E7A80EC7
    Address 76: Park Assist Labels: 4B0-919-283.lbl
    Part No: 4B0 919 283
    Component: Parkingsystem A3 RDW D18
    Coding: 00103
    Shop #: WSC 01236
    VCID: E6C8B7BB821C5F283B9
    2:-
    Sunday,25,November,2012,18:58:30:31506
    Coding: 10710
    Shop #: WSC 02629
    Coding: 18448
    Shop #: WSC 01236
    Coding: 00041
    Shop #: WSC 01236
    Coding: 01104
    Shop #: WSC 01236
    1 Fault Found:
    01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
    32-10 - Resistance too High - Intermittent
    Coding: 01002
    Shop #: WSC 01236
    Coding: 01444
    Shop #: WSC 00402
    Coding: 00032
    Shop #: WSC 00652
    Coding: 00001
    Shop #: WSC 00953
    Coding: 00014
    Shop #: WSC 01236
    Coding: 00205
    Shop #: WSC 00757
    Coding: 00103
    Shop #: WSC 01236
    N88 GGY
    2002 Noggy Blue S3
    With Beige Alcantara and Black Leather
    18 x 8.5 Mercedes Eltanin Alloys, 225/40 18 Tyres, 20 front and 25mm rear PCD Adapters,AP Coilovers,
    Revo Stage 2 Map, Relentless V3 Manifold, 3" Downpipe, Custom Decat, QST Milltek Catback Exhaust, 80mm R-Tech/SFS TIP,
    S2000 Air Filter, Forge FMIC, Forge 008p DV, N249 Delete, Competition Clutches 6 Paddle Clutch with Single Mass Flywheel,
    Gti International 2013:- 1/4 mile - 13.52s
    27,099
    If its a genuine interface, just fire an email of to Ross-tech who will happily advise how to code them again.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Your pump coding is 00032
    This means you've coded the alarm and remote locking out, you need to recode to turn them back on
    Try something like 13130 then add or subtract the number for alarm beep
    Guessing its add 32 ?
    If so you would enter 13162 as the code
    Then recode fobs
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Oct 2007
    Quote Originally Posted by slydog18 View Post
    If when you press the test and your remote is 'recognised' ok, then what your doing wrong is saving both remotes at the same time.
    Enter in the number of remote's as 1 remote, press 'test' press button on remote, says 'recognised', save, exit, then repeat the 'exact' process for the second remote (entering 1 again for number of remote's).
    Hope it helps.
    slydog18's Avatar
    Jul 2011
    Luton, U.K.
    139
    Quote Originally Posted by Sarge786 View Post
    Hope it helps.
    My remotes were not recognized as there was no change or confirmation when button pressed. Will try the code that olds_kool has given above. It seems that is where I entered the code incorrectly. Olds_kool, Is that what you believe to be the correct code or just a random number that sound like the correct one?
    N88 GGY
    2002 Noggy Blue S3
    slydog18's Avatar
    Jul 2011
    Luton, U.K.
    139
    Ok, I went out a recoded using 13130 and success!! Saved a key and it locks/unlocks. Am I right in thinking that if I took away the 32 that it says is the auto lock then it would be de-activated or do you add the 32 to switch between on and off? I saved the code as 13098 and alarm still arms etc. but have not driven it yet to see.
    N88 GGY
    2002 Noggy Blue S3
    slydog18's Avatar
    Jul 2011
    Luton, U.K.
    139
    Turns out that although its genuine you have to register for $99 as I bought it second hand. Not gonna happen as it took me ages to buy a lead in the first place. Oh well.....
    N88 GGY
    2002 Noggy Blue S3
    27,099
    Thats how it works mate I'm afraid if its 2nd user, otherwise RT would never make any money & VCDS would never exist, but thankfully it does exist, as you've resolved your issues, so maybe that 99 bucks is worthwhile after all fella
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,856
    Received my lead today - thanks to NHN - and was familiarising myself with a few bits! but when I shut it down a few bits, including my C\L wouldn't work. after a little hyper-ventilating and remembering seeing this thread! I scanned for errors and not finding anything different to my initial scan, it dawned on me that I had been testing the Transport Mode setting to see what it did! Turns out it switches off the DRL's, Interior Lights and ...yep, you've guessed it ...Remote Central Locking! Exiting Transport Mode returns everything to normal.
    Whew!
    Perhaps this was the cause of the Central Locking failure for the O\P?
    Note: I'm not sue if it changes any of the Chassis\Running Gear settings, but I didn't drive it anywhere so I never found out.
    2009 A3 SB 2.0T DSG S line
    slydog18's Avatar
    Jul 2011
    Luton, U.K.
    139
    Just a bit more advise please, I know you have to add certain numbers to activate something but what if you want to de-activate it? Do you minus that amount?
    N88 GGY
    2002 Noggy Blue S3
    slydog18's Avatar
    Jul 2011
    Luton, U.K.
    139
    All done now....thanks for the replies
    N88 GGY
    2002 Noggy Blue S3
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    Glad you got it figured out by yourself
    You really were on a hiding to nothing though, as you wanted support for something that you were not willing to support yourself ?
    how does that work?
    You may think that $99 is a lot of money for ‘nothing’ (or the odd e-mail reply from Ross-Tech) but when you consider the R&D that they put in AND offer you free lifetime updates and support, then perhaps you will see where your hard earned goes.
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
  1. First use of VAG.COM and now remote locking not working!!
    By slydog18 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2012, 19:46
  2. Remote locking not working???
    By locost47 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd February 2010, 19:15
  3. Is it worth getting VAG-Com and Cable
    By S3MHT in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2007, 10:40
  4. VAG Com and Cruise Control
    By S-T in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2006, 00:47
  5. vag-com and warranty
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2004, 16:33
