AH FabricationsVolks Autos
    mike-turbo's Avatar
    Sep 2009
    64
    Help needed red steering light on dash.!
    ive got a golf plus 61plate the other half damage the steering so ive had to change the wishbone and the steering rack also the airgbag deployed ive not fitted them yet as still looking for some.the battery went flat and the cars light still on even after changing all those parts .here is my vcds log
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Chassis Type: 7N0
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
    VIN: WVWZZZ1KZCW501652
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: Cannot be reached 1100
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Cannot be reached 1100
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 MM HW: 03L 907 425 C
    Component: 1,6l R4 CR td H43 9050
    Revision: --H43--- Serial number: 00000000000000
    Coding: 08114034032501080000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_ECM16TDI02103L906023MM 003006
    ROD: EV_ECM16TDI02103L906023MM_VW36.rod
    VCID: 7DFBFA77EC9B12F04A3
    1 Fault Found:
    6051 - No Communications with Airbag Control Module
    U0151 00 [039] - -
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 3
    Mileage: 6101 km
    Date: 2012.14.30
    Time: 00:06:50
    Readiness: 1110 1000
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 263B400D092200FB641102E9901B0091310000
    VCID: 7BFFF46FFA8F1CC0747
    3 Faults Found:
    00778 - Steering Angle Sensor (G85)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 01:25:11
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 8704
    Count: 166
    Count: 52992
    Count: 0
    Count: 65282
    Count: 0
    01309 - Power Steering Control Module (J500)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 01:25:11
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 8704
    Count: 8213
    Count: 52992
    Count: 0
    Count: 65282
    Count: 0
    01321 - Control Module for Airbags (J234)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 01:25:11
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 8704
    Count: 8226
    Count: 52992
    Count: 0
    Count: 65282
    Count: 0
    Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
    Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
    Component: AC Manuell H19 0304
    Revision: 00001015
    Coding: 0000004003
    ASAM Dataset: EV_ACManueBHBVW36X A01010
    ROD: EV_ACManueBHBVW36X_VW36.rod
    VCID: 7F07007FE69700E058F
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 084 F HW: 1K0 937 084 F
    Component: BCM PQ35 B 110 0651
    Revision: 00110 AC
    Coding: 48180A3A8825F1E0400800C0340000E44B510E88436D896064 8087000041
    VCID: 31631647684326909EB
    Subsystem 1 - Part No: 5M0 955 119 D
    Component: Wischer 24051 26 0513
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AG Labels: 1K0-955-559-AG.CLB
    Component: RLS 240511 05 55 0403
    Coding: 4230BB
    Subsystem 3 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Subsystem 4 - Part No: 1K8 951 605 B
    Component: LIN BACKUP HO H11 9005
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:27:35
    Freeze Frame:
    Term 15 On
    Voltage: 13.20 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:27:35
    Freeze Frame:
    Term 15 On
    Voltage: 13.20 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:27:35
    Freeze Frame:
    Term 15 On
    Voltage: 13.20 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
    Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
    Component: PARKHILFE PLA H08 0116
    Revision: -------- Serial number: 13991111968484
    Coding: 10900B
    VCID: 48955BA3FBD98758A95
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:38:23
    Freeze Frame:
    Temperature: 3.0°C
    Address 15: Airbags
    Cannot be reached
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90422KEK0010F
    Coding: 5080140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_VW36.rod
    VCID: 70E5D343ABC96F98D15
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5M0 920 972 A HW: 5M0 920 972 A
    Component: KOMBI H03 0607
    Coding: 470B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 306513436B492F98915
    2 Faults Found:
    12669184 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Date: 2012.14.30
    Time: 00:48:43
    13638912 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Date: 2012.14.30
    Time: 00:48:43
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 J HW: 1K0 907 951
    Component: J533 Gateway H43 1620
    Revision: H43 Serial number: 270511F1000596
    Coding: 359003
    VCID: 3777285F8627F8A0D0F
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:37:35
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:37:35
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:37:35
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0607
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EAD1412B0D1515481F1
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 5K0 959 701 G HW: 5K0 959 701 G
    Component: Tuer-SG 009 2122
    Coding: 0131764
    VCID: 3669255B412D01A8CB9
    Address 44: Steering Assist
    Cannot be reached
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 5K0 959 702 G HW: 5K0 959 702 G
    Coding: 0132020
    VCID: 3777285F4627F8A0D0F
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
    Component: Radio RCD310 031 0075
    Revision: 01000001 Serial number: VWZ1Z2L3402368
    Coding: 0500040004000A
    VCID: 336F1C4F925F1480EC7
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H43 1620
    Coding: 030B185A
    VCID: F1E3564728C3E6905EB
    Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
    Component: J367-BDM H07 0180
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 5K0 959 703 E HW: 5K0 959 703 E
    Component: Tuer-SG 007 2101
    Coding: 0131216
    Shop #: WSC 01357 011 1012552
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 E HW: 5K0 959 704 E
    Coding: 0131216
    26,762
    Have you cleared each module of fault codes & rescanned as yet?
    mike-turbo's Avatar
    Sep 2009
    64
    yes cleared codes but they just come back on straight away and my steering wheel is solid.would it be another faulty steering rack?
    mike-turbo's Avatar
    Sep 2009
    64
    after looking at the car today there was a broken wire fixed that now i now have power steering but with a yellow light on now.and i have these codes now will i need it tracking as the steering out a bit.
    Chassis Type: 7N0
    04-Steering Angle -- Status: Sporadic communication error 1000
    10-Park/Steer Assist -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 1010
    1 Fault Found:
    U0151 00 [039] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 6101 km
    Date: 2012.14.30
    Time: 00:18:47
    Revision: 00H31001
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:18:57
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 8704
    Count: 8226
    Count: 54016
    Count: 0
    Count: 64770
    Count: 0
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:18:57
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 8704
    Count: 291
    Count: 54016
    Count: 0
    Count: 64770
    Count: 0
    Revision: 00001015
    Coding: 0000004003
    Revision: 00110 AC
    Coding: 009795
    Coding: 4230BB
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:19:25
    Freeze Frame:
    Term 15 On
    Voltage: 14.95 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    Coding: 10900B
    Address 15: Airbags
    Cannot be reached
    Coding: 5080140000
    Coding: 470B00
    1 Fault Found:
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 6101 km
    Date: 2012.14.30
    Time: 00:20:03
    Coding: 359003
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:20:13
    Coding: 000000
    Coding: 0131764
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 233 3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    VCID: 346D1F53575113B8F5D
    1 Fault Found:
    03803 - Steering Angle Sensor for Steering Aid
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 6101 km
    Time Indication: 0
    Date: 2012.14.30
    Time: 00:20:38
    Freeze Frame:
    Battery Volts: 14.9 V
    DU
    Temperature: 17.0°C
    Count: 3
    Steering Angle: 0.00°
    Count: 0
    SteerAng n.Init
    Coding: 0132020
    Coding: 030B185A
    Coding: 0131216
    Coding: 0131216
    26,762
    Just goto the Ross-tech wiki, A3 8P page, look under abs 03 or steering assist 44, follow the procedure to adapt the angle sensor, that will resolve that issue.
  1. Little help needed dv and light on dash...
    By Kelza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th September 2011, 00:05
  2. Help Needed! My ABS light has come on
    By GforceA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2010, 08:31
  3. help please! red warning light
    By tashkin77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2007, 00:57
  4. Help needed !! Engine coil light flashing.
    By Leelacmn in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th February 2007, 15:19
  5. urgent help needed pls - ECU light / limp home mode
    By MrCoont in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th June 2006, 21:29
