Sky InsuranceChris Nott
Results 1 to 8 of 8
    Oct 2012
    help required by some one with vagcom please. 00655 seat belt problem, cash paid
    hi really need someones help . i have an audi 2006 tfsi 3 door , i'm getting code 00655 (passenger side seat belt igniter) on my scanner tool , however it will not delete. i have spoken to steve at c&R of nottingham and he suggests replacing the passenger front seat belt unit. i've tried every where to get a second hand unit but no on seems to have one available that hasn't been triggered. i cant currently afford a new one £220 due to the time of year . so until i can, could some one in the EAST MIDLANDS area please turn the passenger one off only, so i still have some of my air bag system active in the intrim . obviously ill pay you for your service.
    many thanks rob 07854298907
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Hi Rob, welcome to audi-sports.net. Try a pm to user arrkon, he is based in the west midlands. x
    27,113
    Does it log any crash data or its just faulty, cause even if its changed out, the airbag module will show crash data potentially, if no crash then a swap out & clear fault should resolve.
    Oct 2012
    thanks sandra. NHN ive only got a basic code reader plug in tool , so not sure about crash data. it is however the only fault coming up so i would expect more if it was a crash symptom. hopefully ill be lucky
    27,113
    Check the wiring to the seat belt clip, under seat, on the b pillar hidden behind some trims, may have come loose.
    Oct 2012
    hi NHN , CHECKED THE WIRING ON THE SEAT BELT IGNITER BY DISCONNECTING AND RECONNECTING. THERE IS NO WIRING TO THE SEAT BELT CLIP ON THE PASSENGER SIDE(ONLY DRIVERS SIDE) WIRING ONLY GOES TO THE AIRBAG. CHECKED THAT THAT IS CORRECT TOO. THANKS
    27,113
    No need to shout fella.
    Then certainly a more detailed log is required with vcds, Voorhees is in Coventry, maybe a little far.
    Oct 2012
    sorry i left caps lock on. thanks ill get it plugged in by vcds and get it checked. cheers
  1. help required by some one with vagcom please. 00655 seat belt problem, cash paid
    By rob.dren.1981 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th November 2012, 20:18
  2. Any one with vagcom in the southwest???
    By edwards_a3 in forum Smaller (Local) Events
    Last Post: 16th June 2009, 15:05
  3. Any one with VAGCOM near Selby
    By andywa in forum VCDS (formerly VAG-COM) forum
    Last Post: 7th June 2009, 22:38
  4. I might need someone with VAGCOM please!
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2005, 10:36
