Results 1 to 10 of 10
    Nov 2012
    led tail lights pls HELP
    hello everyone.
    i have a 2007 A6 2.0tdi saloon
    i have just bought some led tail`s and have a problem with the fog/reverse.
    this is what i did.
    in vcds controller 46 - Comfort System/coding
    my original code was: 0000251 so i added 0131072(Highline LED) which gave me:0131323 and clicked do it, everything seems fine accept reverse and fog.
    the problem is:
    with the car in reverse, the fog light turns on.
    and with the rear fog switched on the reverse light turns on?
    can anyone please tell me what i did wrong, or better still (and i know this is cheeky) maybe you could tell me what code to put in?)
    thank you in advance
    Jan 2012
    1,837
    Are they genuine audi units?
    Nov 2012
    Quote Originally Posted by A6CR View Post
    no they are after market from GSF but i am using the original bulb holder.
    Jan 2012
    1,837
    If you're using the original bulbs holder you shouldn't need the coding changes
    Take the highline off your coding and see what happens. You may get some bulb errors but try anyway.
    So you're just putting led bulbs into the original bulb holder?
    27,114
    Ok so you're using different lenses, same bulb holder & different bulbs which are led?
    Nov 2012
    its okay ive sorted it now many thanks
    27,114
    Please advise us what the whole picture was & fix so helps others.
    Nov 2012
    i emailed david at audienthusiasts.com and within 10 mins he gave me the solution, all i had to do was add right hand steering to the code and bingo my problem is now sorted.
    i highly recommend audienthusiasts he really knows his stuff, i also made a donation to there website.
    Right hand steering
    +0000256
    =0131579
    27,114
    Ok thats great you solved, but what was the scenario, as its a little confusing, same bulb holders, different lenses & new led bulbs?
    Its very strange, as it should of already been set to rhd, on the assumption your car is rhd that is
    Nov 2012
    yes my car is indeed RHD and yes it is very strange, but it worked.
  1. Tail light problems - help needed
    By A3.Lee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2010, 21:24
  2. Rear LED Tail Lights
    By silverswish in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2010, 16:33
  3. LED tail lights fitted, dash light on
    By sam4191 in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st August 2009, 17:57
  4. New FK1 LED Tail Lights!
    By Toxik-Signal in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2008, 11:58
  5. LED Tail lights
    By sniperlover in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th November 2006, 17:27
