Volks AutosEM Tuning
    Apr 2012
    Oxford
    126
    Possible to adjust brightness of non-LED DRLs?
    Hi all,
    I am hoping some VCDS ninja can tell me whether it is possible to adjust the brightness/power level of the non-LED daytime running lights on a pre-facelift C6 A6, or otherwise recode things to make them accept LED bulbs.
    I have the bi-xenon headlights, and the inner lamps (p21w bulbs) are used solely as DRLs, so I have fitted a pair of LED bulbs with a built-in resistor (LED 382 Canbus Car Bulbs - 360 degrees LED reverse, indicator and rear bulbs resistor included) to freshen up the front-end look and get rid of the ugly yellowness of the incandescents.
    Everything lights up nicely, and I don't get any "bulb out" errors, but I do get a very slight flicker every few seconds, which makes me wonder if slightly upping the current being fed to them might sort the issue... or is this just an unavoidable side-effect of the system constantly checking whether the bulbs are ok? I have also noticed that the bulbs also flicker on every 30 seconds or so when running at night (i.e. DRLs off, headlights on), which has almost certainly got to be the system checking for blown bulbs.
    Much obliged if anyone can offer any ideas how I might resolve this flicker, as I really would like to avoid swapping the manky old bulbs back in
    27,007
    Check for cold diagnosis for the drl's & disable, but I would find some better led's that suit as resistance is probably slightly of.
    Apr 2012
    Oxford
    126
    Fair enough... I think it might have to wait until after Christmas to pull some pennies together and buy my own VCDS cable.
    Jeez, I wish it wasn't such a pain in the buttocks to get to the lights on the C6 platform
    Apr 2012
    N. Wales, LL22
    1,224
    i'm gonna do mine..... but turn them off in the mmi, then hard wire the leds to the igniton
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
  1. Non - LED DRL Bulb?
    By A3 Sport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2010, 21:18
  2. 2010 Post Facelift Non LED DRL Bulbs
    By J8Y PW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2010, 09:22
  3. AUDI A3 2010 NON LED DRL BULBS
    Last Post: 12th July 2010, 14:28
  4. Non LED DRL's Facelift.. Which bulbs?
    Last Post: 14th March 2010, 17:37
  5. Non LED DRLs
    By panamadi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th August 2009, 16:27
