Chris NottSky Insurance
Results 1 to 13 of 13
Thread: Fault codes
    Jun 2010
    Coventry/Warwickshire
    2,074
    Fault codes
    I Just had a local chap check my car ,And these codes came up
    he was messing about for some time ,Now my power steering has gone heavy !
    hes not charging me but i need this car sold to trade up
    please can someone help ,I keep going round in circles on rosstec
    00290 abs wheel speed rear left (G46) sensor 003 -mechanical failure intermittent
    00290 sensor 008 implausible signal -intermittent
    02546-steering limit stop
    005-no or incorrect basic setting/adaption
    Freeze frame :
    Milage
    Temperature
    00778 steering angle sensor (g85)
    000- -
    Freeze frame
    I know theres guys who can sort this on here ,So please help us get this sorted before i torch the ******* car
    Fossie
    Rhubarb Triangle
    3,961
    Try resetting the steering. Full left lock and hold for 5 seconds, full right lock and hold for 5 seconds then back to central. If that doesn't work then you will probably need VCDS to do the basic settings.
    Presumably your man disconnected the battery ?
    Jun 2010
    2,074
    Sorry for late reply ,I disconnected the battery last week
    and ended up with the errors.Seems like this forum has lost its helpful members.
    cheers mike
    Jun 2010
    2,074
    By the way before i removed the battery i had zero errors .
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by SteveL View Post
    Shouldn't have removed the battery should you ? Obviously you did not realise that steering and abs need basic settings carried out with vcds to regain power steering. It's an easy job and anyone with vcds in your area would do it for you. If the mechanic did not have vcds and just a code reader then he has no chance.
    Read this, basic settings are halfway down the page :- VW Golf (1K) Steering Assist - Ross-Tech Wiki
    Don't slate Audi's or forum members just because you have made mistakes !
    There is nothing wrong with the car that a competent mechanic can't fix provided he has the right tools
    Jun 2010
    2,074
    I have a borrowed cable .I am competent enough to wire my own lights in
    I have been through ross tech .
    Can a competent vcds user please help
    Sorry for being such a grouch ,The wife left ,CSA is looming ! The car is up for sale ,3 potential buyers have walked due to the poxy lights ,I am broke!,The steering is like a bloody lorry,.
    I need to sell it to pay her
    Fossie
    Rhubarb Triangle
    3,961
    Sorry about your problems Steve. I have found this guy from the VCDS user map.
    Why don't you contact him and see if he can help
    https://maps.google.co.uk/maps/ms?ms...5&source=embed
    These are his details :- View Profile: Arrkon - Audi-Sport.net
    Jun 2010
    2,074
    Guy read the message and has not replied .
    anyone in Coventry with coding experience?
    26,716
    Steve bell me tomorrow afternoon, PM me & I'll reply with my number
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    Just been over to steve's and had a look.
    During the adaptation process it seems to be failing. See Below
    [Select]
    [44 - Steering Assist]
    [Coding-II - 11] or if that function is not available then use [Sec.Access - 16] instead
    Enter 40168, to enable the basic setting.
    [Do it!]
    [Basic Settings - 04]
    Group 060
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    Upon selecting [ON/OFF/NEXT] it fails and shows "Group 60 Not Available" as if you have not gained the security access...
    It does seem as though the Steering angle sensor adaptations are the root cause of the ABS and Steering assist issues though... Any suggestions Nigel?
    Currently rolling in a SKODA!!!
    26,716
    There are 2 areas you can set the sensor, 03 & 44 depending on the car, did you try both?
    Arrkon's Avatar
    Oct 2010
    1,633
    Fault codes
    Yes mate both ABS and Steering assist we're tried, though [03]steering assist refused security same constant (40168)
    Jun 2010
    2,074
    I do not know what is going on ,But now i am getting flashing lights and the flat tyre light is on
    im at the end of my tether ,can anyone please help ,no power steering flashing lights
    im starting to absolutely hate Audis
  1. S6 Fault codes
    By bigmoose in forum General Technical / How To
    Last Post: 16th June 2005, 16:16
  2. Help: Fault code 16795
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 17:17
  3. information on fault codes
    By vwjin in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2004, 00:45
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
