Sky InsuranceAH Fabrications
Results 1 to 14 of 14
Thread: Audi A6 4G
    amar06fbr's Avatar
    Vorsprung Durch Technik
    Apr 2010
    West Yorkshire
    1,033
    Audi A6 4G
    hi chaps, iv retrofitted the new led xenons into a A6 4G iv used the kufatec wireing. the instruction on the coding part is somting i dont understand and i cant code them the drl are working but the cornering lights are on with the drl and theres no flash. anyone got the coding?
    thanks
    A.
    For Sale
    climate control (double din non chrome)
    Black roof lining (sportback)
    pm me for more info..
    BBM: 28E07323
    My Panoramic RetroFit
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    this is the coding i got of kufatec ins;
    encoding
    To carry out the vehicle code, please contact an Audi party. connection
    establish the diagnostic unit - choose vehicle self-diagnosis. Please complete the coding
    Step by step in accordance with the following illustrations by.
    address 09
    Byte 00 - HEX - 26
    Byte 02 - HEX - 20
    Byte 06 - HEX - 9F
    Byte 14 - HEX - 1D
    Byte 15 - HEX - 0C
    For Sale
    BBM: 28E07323
    Sep 2007
    North-East UK
    96
    Can you post a diagnostic scan of your car to show the current coding for module 09
    Hopefully we can then advise what needs to be changed.
    Steve
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels. Retrofit Armrest, Cruise Control & Gauge Sweep. VCDS.
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    Hi Steve, thanks for the reply, yea here is the scan;
    Chassis Type: 4G0
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72
    VIN: WAUZZZ4G6CN082751
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    3B-Sensor Elect. -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CGLC) Labels: 03L-906-018-CGL.clb
    Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
    Component: R4 2,0L EDC H25 2023
    Revision: 45H25---
    Coding: 12194012242401080000
    Shop #: WSC 02311 785 00200
    ASAM Dataset: EV_ECM20TDI01103L906018LA 003009
    VCID: 74ECABBEDF0A33B835D
    1 Fault Found:
    10065 - Mass Air Flow Sensor (G70)
    P0104 00 [167] - Intermittent
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 00:24:28
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
    Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
    Component: ESP PREMIUM H09 0361
    Revision: -------- Serial number: --------------
    Coding: 06A087016005E1808B00
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ESPPremiAU57X 004028
    VCID: 366851B689F661A8CB9
    2 Faults Found:
    0687 - Function Restriction due to Received Malfunction Value
    U1113 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 00:23:21
    0688 - Function Restriction due to Implausible Message(s)
    U1112 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 00:23:18
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 BG HW: 4H0 907 064 BG
    Component: BCM2 2.0 H31 0333
    Revision: 00002001
    Coding: 03B93006000000000000
    VCID: 6FE6A4D2BE2C1060C8F
    Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
    Component: J764 ELV MLB H39 0046
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 16
    Mileage: 19588 km
    Time Indication: 0
    Date: 2012.05.07
    Time: 00:23:25
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 4G0 820 043 G HW: 4G0 820 043 G
    Component: KLIMA 2 ZONEN H10 0062
    Serial number: 09111100040966
    Coding: 34220008A0
    ASAM Dataset: EV_AirCondiBasisUDS 002037
    ROD: EV_AirCondiBasisUDS.rod
    VCID: 234E98E22A64E4001C7
    3 Faults Found:
    0267 - Sensor for Refrigerant Pressure and Temperature
    B10C2 21 [009] - Signal Amplitude Too Low
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Reset counter: 232
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 01:17:47
    0276 - Engine Off Timer Performance
    P150A 00 [009] - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 232
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 00:00:48
    0315 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 01:17:47
    Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
    Part No SW: 4H0 907 063 BA HW: 4H0 907 063 A
    Component: BCM1 2.0 H12 0100
    Revision: 12012002 Serial number: 00000001103011
    Coding: 690000108034A7600405008000005F5F0F9D86082708010100 0004402000
    VCID: 68D4CFCE9BC2C758895
    Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A
    Component: WWS57X 110926 H35 0051
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 02512B
    Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
    Component: E1 - LDS H07 0044
    Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
    Component: Humidity_Sens H02 0002
    4 Faults Found:
    02394 - Parking Light Left Front (M1)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 17
    Mileage: 19588 km
    Time Indication: 0
    Date: 2012.05.07
    Time: 00:43:00
    02395 - Parking Light Right Front (M3)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 17
    Mileage: 19588 km
    Time Indication: 0
    Date: 2012.05.07
    Time: 00:43:00
    02745 - Bulb for Daytime Running Light; Left
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 19588 km
    Time Indication: 0
    Date: 2012.05.07
    Time: 00:43:00
    02746 - Bulb for Daytime Running Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 19588 km
    Time Indication: 0
    Date: 2012.05.07
    Time: 00:43:00
    Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
    Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
    Component: PARKHILFE ACC H07 0043
    Revision: 11001001 Serial number: 55901131202858
    Coding: 080207
    ASAM Dataset: EV_EPHVA18AU57X0000 002005
    ROD: EV_EPHVA18AU57X0000.rod
    VCID: 3B7E4082B2D4BCC0347
    No fault code found.
    Address 15: Airbags (J234) Labels: None
    Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
    Component: Airbag10.43 H40 0040
    Revision: -------- Serial number: 003JG005BHH2
    Coding: 30323436313230303235554A305234473053
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_AU57.rod
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB405R0UJCIBH14
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB405L0TGJED90Y
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515JRB405J0TO4MCHNF
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3525JRB405F0TGJI615I
    Crash sensor for front airbag; driver side:
    Serial number: 3554VRB405L0TO4ONHF.
    Crash sensor for front airbag; passenger side:
    Serial number: 3564VRB405L0TO4OHPM4
    1 Fault Found:
    1048581 - Databus
    U1123 00 [008] - Received Error Message
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 17
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 00:23:20
    Address 16: Steering wheel (J527) Labels: None
    Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
    Component: Lenks.Modul H05 0201
    Revision: 00000000 Serial number: 20111108000412
    Coding: 000015
    VCID: 306467AE63924F98915
    Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
    Component: E221 - MFL H08 0009
    Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
    Part No SW: 4G8 920 950 K HW: 4G8 920 950 K
    Component: MDieGb H34 0209
    Revision: 25450205 Serial number: 658081111593046
    Coding: 33A4100003012600010000
    ASAM Dataset: EV_RBC7KMID 004045
    ROD: EV_RBC7KMID.rod
    VCID: 37765CB28EFC98A0D0F
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 4G0 907 468 F HW: 4G0 907 468
    Component: J533--Gateway H08 0214
    Revision: -------- Serial number: 00000000275450
    Coding: 00CD074400
    ASAM Dataset: EV_GatewUDS 001025
    ROD: EV_GatewUDS_AU57.rod
    VCID: 336E68A29A847480EC7
    Control unit for battery monitoring:
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0141
    Serial number: 00000000003790924589
    Voltage stabilizer:
    1 Fault Found:
    4875 - No Communication with Instrument Cluster
    U0155 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 01:55:04
    Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
    Part No SW: 4G0 907 637 HW: 4G0 907 637
    Component: SARA 3D H02 0004
    Revision: -------- Serial number: EJ1BPA3200VK3A0
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_SARA 006014
    ROD: EV_SARA_AU57.rod
    VCID: EBDE30C202346C40647
    Address 42: Door Elect, Driver (J386) Labels: None
    Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
    Component: TSG FA H05 0212
    Coding: 011C16204001620002080002
    Shop #: WSC 02312 785 00200
    VCID: 42803D66DD3ECD08771
    Address 44: Steering Assist (J500) Labels: None
    Part No SW: 4G0 909 144 J HW: 4G0 909 144 G
    Component: RCEPS H35 0008
    Revision: 00001000 Serial number: 0029248771
    Coding: 101000010000
    ASAM Dataset: EV_RCEPS 007007
    ROD: EV_RCEPS.rod
    VCID: 306467AE6B924F98915
    1 Fault Found:
    5258753 - Steering End Stops Not Learned
    C10AC F0 [137] - Unknown Error Elaboration
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 232
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 00:42:42
    Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
    Revision: 00002001 Serial number: 0162181465
    Coding: 013B062220B904408320090400010400000000000000000000 0000000000
    Subsystem 1 - Part No: 4G0 951 177
    Component: DWA-Sensor H01 0010
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    3 Faults Found:
    00218 - Humidity Sensor (G355)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 231
    Mileage: 19588 km
    Time Indication: 0
    Date: 2012.05.07
    Time: 01:04:10
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 16
    Mileage: 19588 km
    Time Indication: 0
    Date: 2012.05.07
    Time: 00:23:25
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 16
    Mileage: 19588 km
    Time Indication: 0
    Date: 2012.05.07
    Time: 01:55:05
    Address 52: Door Elect, Pass. (J387) Labels: None
    Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
    Component: TSG BF H05 0212
    VCID: 4182326AD838D6106EB
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
    Component: EPB-4 H03 0012
    Revision: -------- Serial number: 00000000172740
    ASAM Dataset: EV_ParkiBrake 001022
    ROD: EV_ParkiBrake.rod
    VCID: 2A5075C64D4E35485F1
    1 Fault Found:
    465152 - Function Restriction due to Received Malfunction Value
    U1113 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 17
    Mileage: 19588 km
    Date: 2012.05.07
    Time: 00:23:20
    Address 5F: Information Electr. (J794) Labels: None
    Part No SW: 4G0 035 193 D HW: 4G0 035 193 D
    Component: RMC Cnct Nav H52 0761
    Coding: 0101010001415B47002B060301010000010000
    VCID: 244C9BFE276AE33865D
    Subsystem 1 - Part No: 8X0 919 884 D
    Component: P13-50-11.06 0002
    Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
    Component: DU6 Basic H42 0084
    Subsystem 3 - Part No SW: 4G2 919 710 B HW: 4G2 919 710 B
    Component: E380 BDT C7 H11 0204
    1 Fault Found:
    02259 - Information Display and Control Head (Front) (J685)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 16
    Mileage: 19588 km
    Time Indication: 0
    Date: 2012.05.07
    Time: 01:04:05
    Address 62: Door, Rear Left (J388) Labels: None
    Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
    Component: TSG HL H04 0212
    Coding: 010814204001620002080002
    VCID: 448C3B7EC72AC33845D
    Address 72: Door, Rear Right (J389) Labels: None
    Component: TSG HR H04 0212
    For Sale
    BBM: 28E07323
    Jan 2012
    1,837
    Audi A6 4G
    Clear all faults and rescan
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    this scan was after i cleared all faults, the is kind of striped atm lol.
    For Sale
    BBM: 28E07323
    Jan 2012
    1,837
    Audi A6 4G
    Quote Originally Posted by amar06fbr View Post
    Have you got the self levellers for the suspension and a new front bumper with washer jets? If not, you're not legal
    If I recall correctly (open to criticism on this btw) you should have two stray wires coming from the wiring adapter which need to be plugged into your central conv module under the steering wheel.
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    Quote Originally Posted by A6CR View Post
    erum working on them, but will be looking to fit them later on because my a3 is curently not on the road and i need a car so am going to do them after i get my a3 back on the road.
    yeap i have wired the 2 wires into the central conv.
    For Sale
    BBM: 28E07323
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    anyone?
    For Sale
    BBM: 28E07323
    Jun 2011
    Great Melton Norfolk
    1,356
    Thats a lot of fault codes, has it been crashed? when was it crashed?
    27,129
    encoding
    address 09
    Byte 00 - HEX - 26
    Byte 02 - HEX - 20
    Byte 06 - HEX - 9F
    Byte 14 - HEX - 1D
    Byte 15 - HEX - 0C
    Are you saying you tested this coding & it didnt work or you just dont know how to implement the coding given above?
    amar06fbr's Avatar
    Apr 2010
    West Yorkshire
    1,033
    [QUOTE=NHN;1722473]Are you saying you tested this coding & it didnt work or you just dont know how to implement the coding given above?[/QUOTE
    nope i havent tried that coding because vcd dont have HEX listed and on each bit under the byte there boxes to be ticked an untick but dont have info on what each bit is for.
    For Sale
    BBM: 28E07323
    Sep 2013
    Manchester
    7
    Did you manage to code the LED headlights for your A6? I am currently installing the bi Xenons on my A6.
    Mo-S3's Avatar
    North West
    706
    Any update on this?
    Or anyone got any xenon lights for sale??
  1. Audi-Sport Trackday Castle Coombe 2nd April 2003
    By johneroberts in forum Major UK Events
    Last Post: 26th March 2003, 18:25
  2. FYI: Audi Approved Oils for the S3
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2003, 09:56
  3. Welcome to RS4 forums at audi-sport
    By Administrators in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th January 2003, 13:44
  4. Links to All Things Audi
    By Joshie in forum General Chat
    Last Post: 6th January 2003, 12:31
  5. Audi Fest?? Is it on?
    By Moresauce in forum Major UK Events
    Last Post: 6th January 2003, 12:12
