Badger5JMB Retrofits
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,322
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    VCDS Fault codes inside' Solving it
    Searched and not found an exact reason. VCDS Codes below.
    Replaced the Wheel speed sensor cleaned the ring and inspected and changed key fob battery. but no change and now have these codes. its pissing me off, I have ABS light' Traction light and engine management. its intermitten abs and traction only comes on when stationary or second time turning the cart back on also have no speedo which is also intermitten (not all the time)
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04495
    Shop #: WSC 06435
    VCID: 264881E4C20EBB287B9
    1 Fault Found:
    00283 - ABS Wheel Speed Sensor; Front Left (G47)
    30-00 - Open or Short to Plus
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0203
    Coding: 00001
    Shop #: WSC 63351
    VCID: 32606DB4FEC6D788E71
    1 Fault Found:
    01312 - Powertrain Data Bus
    79-00 - Please Check Fault Codes
    So i have done.
    Replaced with new sensor and cleaned and inspected everything and no joy. and the speedo not working 50% of the time puzzles me too
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    Aug 2009
    north east U.K
    1,322
    Last thing a need to double check on monday is wiring but sure its fine
    Aug 2009
    north east U.K
    1,322
    anyone' ive changed the wheel bearing too now hoping it would solve it' got it in my head that it might only happen on lock
    Jun 2011
    Great Melton Norfolk
    1,356
    sounds like abs unit , if traction control will not turn off
    Aug 2009
    north east U.K
    1,322
    need to test it some how. googled abit but havnt found much
  1. VCDS Fault Code - 01403
    By Brodster in forum VCDS (formerly VAG-COM) forum
    Last Post: 6th September 2013, 13:52
  2. VCDS Fault Code 00716 Help !
    By areeb1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2012, 04:33
  3. vcds fault code
    By lee58uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2012, 15:00
  4. VCDS Fault Codes
    By Andy Shipton in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2011, 20:37
  5. VCDS Fault codes . . .
    By Olly_K in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st September 2006, 15:29
